So, anyone else have this trouble and if so, what do I need to do to get this machine back up and running asap?
thank you,
Curtis
There is no way to tell if they are good or bad without using a meter to measure the resistance.cratica wrote:Thank you. I located the fuses on the circuit board but they all look fine. Are the microfuses supposed to burn through when bad like regular fuses? Or can be look fine but be bad internally?
