Onyx Rev7
Posted: Fri Sep 12, 2014 6:19 pm
by bauf
Ok,so i got my max2 kit today and i'm @ 5C in the manual. But the manual doesnt include the rev7. On the bed i can only see 1 LED slot and 1 Resistor slot, but i got 2 LEDs and 2 Resistors.. so i guess they were just included in the kit in case i got a rev6,or what?
oh,and another thing in the manual; Strip about 1/8” from the white & green wires. These are used as the power wires for the hot
end LED and are installed as shown below. Make sure you've got the green wire attached to the “+”
pad and the white wire attached to the "-".
here's a picture of it. I don't have that that "HOT - + " tabs on my rev7 bed. So what do i do with the green and white cable then?
Re: Onyx Rev7
Posted: Fri Sep 12, 2014 7:02 pm
by bauf
So this is what i've done so far. What are those tiny holes for at the top? There are 7 at the top and 7 right over the Thermistor hole.
oh and i don't have kapto tape yet,it's being shipped,so i'm gonna put some kapton on there when i get it
Re: Onyx Rev7
Posted: Fri Sep 12, 2014 7:30 pm
by Mac The Knife
The tiny holes are to transfer the power to the otherside.
Re: Onyx Rev7
Posted: Fri Sep 19, 2014 8:05 am
by Tropicalsq744
yeah, i'm stuck at this part too. not sure what to do with the green wire.
Re: Onyx Rev7
Posted: Fri Sep 19, 2014 8:50 am
You can connect them either way, but you need the LED anode and cathode to line up accordingly. It doesn't technically matter which side of the LED you place the resistor on because it's just a series circuit, but my rule of thumb has always been to put the resistor on the anode side so that you drop the positive voltage. I'm used to working in cars where everything is ground, so you current limit the positive lead (to eliminate ground loops and make shorts less catastrophic).
I was going to provide you with an illustration, but I need to remind Oly that the Rev 7 bed isn't on GitHub yet.
Re: Onyx Rev7
Posted: Fri Sep 19, 2014 11:52 am
You don't do anything with the green and white wires. The feature they were for was deleted from the design, so don't worry about it.
I'm going to be doing a major update to the assembly manual sometime after MFNY and all the multi-rev stuff will be deleted and will only contain the currently shipping stuff. It'll make it a lot easier on new builders that way.
Re: Onyx Rev7
Posted: Fri Sep 19, 2014 3:07 pm
by BONE
geneb wrote:You don't do anything with the green and white wires. The feature they were for was deleted from the design, so don't worry about it.
- rejoicing.gif (478.88 KiB) Viewed 8780 times
Re: Onyx Rev7
Posted: Fri Sep 19, 2014 4:35 pm
Were they going to put an LED indicator in the bed for the hotend too?
Re: Onyx Rev7
Posted: Fri Sep 19, 2014 4:39 pm
by Nylocke
Rev6 had that. That was a cool feature in my opinion
Re: Onyx Rev7
Posted: Sun Sep 21, 2014 3:11 pm
by prussiap
whew. glad I saw this while I was building mine. No rev 7 in the manual so assumed it was super new
I "think" the soldering is common sense just was thrown off by the extra LED and resistor..
also my base is soo not the same one as in the picture of the manual
https://www.dropbox.com/s/m390gojtldlw1 ... 9.jpg?dl=0
that threw me off but I think I got it.
Re: Onyx Rev7
Posted: Sun Sep 21, 2014 4:01 pm
by bauf
haha,yeah.. it was pretty straight forward, but i was also throw off by the extra led and resistor.
Re: Onyx Rev7
Posted: Sun Sep 21, 2014 6:25 pm
by Nylocke
prussiap wrote:whew. glad I saw this while I was building mine. No rev 7 in the manual so assumed it was super new
They changed the base to allow room for more ventilation for bigger PSUs. Instead of perforations, they put large holes
