Rostock Max V2 w/ Rambo 091 and using repetier host.
I have an .stl that prints ok at normal feedrates, 30-60mm/s range for teh various parts of the print.
But since it is a small part, the ABS stays too hot between passes, and the part ends up getting distorted.
So I slowed it down to 25% using the feedrate slider in repetier host manual Control tab, and it is still too fast.
I created a new slicer profile that slows things down to between 1-2mm/s, and run the part, the RAMBO will reset anywhere from 15s to 1 minute into teh print.
I also tried a faster slice profile, with speeds of 7-15mm/s, and this prints fully-but if I slow it down using the feedrate slider, the same thing happens, the RAMBO will reset partway through the print.
I thought maybe it was USB comm issues, so I saved the g-code and transferred it to the SD card, and printing from teh card with the PC disconnected does the same thing-RAMBO resetting.
I only have this problem at slow feedrates; does anyone have any insight into this?
RAMBO keeps resetting if I slow the feedrate down, or....
Re: RAMBO keeps resetting if I slow the feedrate down, or...
I cannot recommend any remedies for the resetting problem but the forum standard response is print 2 of the parts at the same time.
- nitewatchman
No insight into the resetting but when I run into the problem of too much heat I set the slicer to turn on the three layer fans.
