Issues with printing
Posted: Sun Nov 02, 2014 6:59 pm
I have my Rostock V2 calibrated as well as I can (having done the calibration routine until I can do it with my eyes closed
Can anyone point me in the correct direction as to what setting would be causing the layers to print with these gaps? The attached pic is the bottom layer of a partially printed Octopus Fridge Magnet - printed with ABS.
My print bed consists of; copper heat dispersion plate, borosilicate plate, layer of PEI (Polyetherimide) Sheet, Opaque Off-White, Standard Tolerance, ASTM D5205 PEI0113, 0.03" Thickness adhered to the borosilicate plate with the TapeCase 468MP 0.5in X 20yd Adhesive Transfer Tape.
I am running my prints with the following characteristics; (please let me know if you need any additional information)
Software - Repetier - Host V1.0.5 with Slic3r V 1.1.7
Default Rostock hot end (although I do have a E3D V6 waiting in the wings once I can get the mounts to print correctly for attachment
SLic3r settings;
Print Settings
Layer Height = 0.2 mm
First Layer height = 0.25 mm
Fill Density = 40% Honeycomb
Top/bottom fill pattern = rectilinear
All speeds = 30 mm/s
Filament Settings
Diameter = 1.75mm
Extrusion multiplier = 1
Extruder Temp = 225
Bed Temp = 90
EEPROM Settings - see attached jpg
Thank you in advance for any help that you can provide.
George
SLic3r settings;
Print Settings
Filament Settings
Diameter = 1.75mm
Extruder Temp = 225
Bed Temp = 90
George
