PEEK Fan Shroud Overhang Curling
Posted: Fri Nov 21, 2014 6:25 pm
I am trying to print the PEEK Fan Shroud and overall 90% of the print is coming out AMAZING.
The biggest issue I am having is that once the print gets about 21mm from the print bed the overhang begins to curl upward and the hot end hits the curl and pushes the print out of place. This occurred while I was printing last night around 11PM and I will estimate it was ~50 degrees Fahrenheit outside. I had the door open on the other side of the apartment trying to purge some of the ABS smell. Here is a picture of what the print looks like. It is the left front overhang that the hot end snags on. Thanks for any help!
EDIT: I was on Reddit/r/fixmyprint and it was recommended to "Since you've got a rostock, take advantage of the speed and set your z-lift to 1mm, fixes those snags on curling filament
." Would this be a solution or a quick fix?
[img]http://i.imgur.com/6ZDDPRs.jpg[/img]
