A video on finding the perfect filament temp
Posted: Tue Dec 02, 2014 2:46 am
by McSlappy
https://www.youtube.com/watch?v=POaL2GGBHGM
It's a short one :) but hopefully is helpful in tuning the myriad of filaments / brands you've got laying around.
Cheers.
Re: A video on finding the perfect filament temp
Posted: Tue Dec 02, 2014 8:05 am
by teoman
Thank you again for the awesome video.
I had watched another one on youtube, where the GCode is modified a bit to decrease the temperature in steps. And in the end you end up with a shape that you can observe the temperature differences on a single object.
Posted: Tue Dec 02, 2014 5:54 pm
by bot
Along these same lines, there is a plugin for Cura that varies the print temperature based on the actual print speed (because Cura slows it down sometimes).
http://wiki.ultimaker.com/CuraPlugin:_Flowthermostat
Using this video to find the max and min temperatures to vary between would lead to really great results.
Posted: Wed Dec 03, 2014 5:20 am
bot wrote:Along these same lines, there is a plugin for Cura that varies the print temperature based on the actual print speed (because Cura slows it down sometimes).
Thanks for the info on this plugin. I did not know it even existed.
