Latest problem is with extruder stepper
Posted: Sun Dec 14, 2014 7:35 pm
by Kitecraft
After failed print after failed print, I can only conclude that the heat from the extruder stepper is causing the filament to soften to the point that it just squishes and won't feed.
Is there a way to fix this problem?
Thanks
Re: Latest problem is with extruder stepper
Posted: Sun Dec 14, 2014 7:55 pm
by BenTheRighteous
You could point a desk fan at the motor long enough to print a fan shroud for it, then hook up a small 20mm fan or something for a more permanent installation. Wire it up to the same wires that feed the PEEK fan perhaps?
Posted: Sun Dec 14, 2014 8:11 pm
by dunginhawk
i will totally concur, not that is causes me issues, but that stepper motor gets BLISTERING hot.
Posted: Tue Dec 16, 2014 8:44 am
by Kitecraft
This is what happens between 1.5 and 2.5 hours into every print.
Posted: Tue Dec 16, 2014 10:32 am
How fast are you printing? What temp?
I've found that things like that happen when you go too fast at too low a temperature.
Posted: Tue Dec 16, 2014 11:07 am
by Kitecraft
geneb wrote:How fast are you printing? What temp?
Interesting! Thank you, I'll investigate that further.
Cheers
Posted: Tue Dec 16, 2014 9:44 pm
by RichardMac
I had a simular problem. My extruded motor would get super hot with jobs that had lots of retracts. I ended up attaching a fan with a built in heat sink that I had salvaged from a old video card. I wired it inline with the peek fan. Solved the problem of the hot motor.
Posted: Tue Dec 16, 2014 9:49 pm
by Kitecraft
RichardMac wrote:I had a simular problem. My extruded motor would get super hot with jobs that had lots of retracts. I ended up attaching a fan with a built in heat sink that I had salvaged from a old video card. I wired it inline with the peek fan. Solved the problem of the hot motor.
Also interesting as this print does in fact have a lot of retracts. Thanks for the post.
I like the idea of heatsink/fan. I have tons of computer equipment including a few older style CPU coolers.
Cheers
Posted: Tue Dec 16, 2014 9:53 pm
by RichardMac
This is like the part I salvaged. Used some paste between the sink and the motor
http://www.ebay.com/itm/131282045366?ru ... 26_rdc%3D1
Posted: Tue Dec 16, 2014 10:15 pm
by Kitecraft
I have a couple of those laying around too lol
Posted: Tue Dec 16, 2014 11:51 pm
by Kitecraft
I think both of those suggestions were very helpfull. The latest print (which is actually still printing at this moment!) is doing very good.
I made 2 changes.
1: I reduced the speed by 25%
2: I switched to RepetierHost and Sli3er.
Sli3er has produced a huge reduction in retracts and the filitment extruder is over 12 degrees cooler!
Slower seems to have produced a good result too
Thank you for your feedback and suggestions. They have been very helpfull to me.
Here's a vid for ya.
[youtube]
http://www.youtube.com/watch?v=ITOsNOVZIFs[/youtube]
Cheers!
Posted: Fri Dec 19, 2014 4:19 pm
by Kitecraft
I spoke too soon.
Still can't get a successfull print with Red PLA.
