Cannot remove bowden from PTF connector
Posted: Tue Dec 16, 2014 11:50 pm
by BenTheRighteous
I'm trying to swap my stock hotend for an e3d, but I want to reuse my old bowden tube. However no matter what I try, I cannot unseat it from the PTF connector (either the hotend side or ezstruder side).
I've got channel locks that I'm using to compress the grey collar, and pliers that I'm using to try and grip the bowden with, but it holds fast. I've tried compressing and pushing, pushing and compressing, compressing and jiggling... nothing. Might as well be superglued.
The only advice I found was in this thread ( http://forum.seemecnc.com/viewtopic.php?f=54&t=2569 ) that said to push the bowden all the way first to relieve tension, then compress the collar, then pull - but that didn't help.
I don't want to cut this thing off, but I'm starting to think I have to. I've already damaged the bowden a little with the pliers. Any advice?
Re: Cannot remove bowden from PTF connector
Posted: Wed Dec 17, 2014 2:05 am
by precisionpete
What your doing is push the collar and keep it held in while removing the tube is correct.
You shouldn't need pliers or any tools, just a guess but this is the problem.
Just use fingers to remove this, should be stuck. Only thing I can think of is you have melted this with the original hot end but kinda unlikely.
Instead of making yourself crazy step back and buy another tube, then the old one will come right out :)
You will then have an extra tube for the next machine!
Posted: Wed Dec 17, 2014 8:24 am
by JFettig
The little fingers dig into the soft tube. I had a hard time with mine yesterday, I unscrewed it from the hot end, pushed the tube and collar in then pulled really hard. It came out
Posted: Wed Dec 17, 2014 11:22 am
by BenTheRighteous
I wound up just giving up and cutting the stupid thing off. I tried hands, I tried tools, I tried it both in and out of the hotend... no success.
The e3d has a MUCH nicer push fit connector. That one actually lets go when it's supposed to.
Posted: Wed Dec 17, 2014 11:43 am
by Chrissi
I end up unscrewing the connector, never can get it out.
