Rostock Max V2 as first 3d Printer
Posted: Mon Dec 22, 2014 2:49 pm
Hi there,
I'm planning to buy the Rostock Max V2 as my first 3d printer. My focus will be making cases and acessoires for diy projects of all kinds and printing parts for my car. That's why i need one that can handle ABS filament and has a lot of printing space, so i figured this might be the best one.
Assembling the Kit might be a bit of a challenge but i think it will be a good learning experience and won't be impossible to do. I'm somewhat experienced in messing around with all kinds of technical stuff, working as car mechanic and doing various arduino projects that involve everything from 12/230V motor regulation to climate control. Currently i'm working on getting my own arduino based washing machine control unit done.
Since i live in germany i will probably order it from robosavvy.com, to avoid paying 300+€ in toll and taxes.
I've already assembled a list of ebay links with all the tools. Seeing i would even need wrenches in imperial sizing.
However i wanted to ask some questions before i get started:
- What about this 'disappering purple' glue stick that is mentioned in the manual? Do i really need that special kind? What is it for? I'd rather see if i could improvise something than order a 25$ gluestick over ebay. What does it do that a simple 40 cent gluestick can't do?
- Other than the tools and things advised in the manual and some filament, what would you recommend buying along to get started? Like for a MIG welder i would definitely order some spare nozzles because sometimes they tend to weld shut. Is that the case with 3d printing? Are there any other weak points or things that might need replacing from time to time?
- Any other tips and advice about this project in general?
- Is there a place in europe to buy spare parts from incase i ever need them?
- Can i get started printing ABS with this printer right away or are there recommended adaptions? Or would you advise me start off with PLA until i'm a little more experienced?
- Can i just use any spool of 1.75mm filament of any type i desire? Or are there spool size limitations? Are there filament types it does not support?
I'm looking forward to starting my journey into the promising world of 3d printing
