Is the problem my thermistor... again?
Posted: Sun Jan 04, 2015 2:35 am
Hi All,
Just started up my Rostock Max v2 again after about 2 months downtime. I've only printed 4 small things and the fan shrouds since assembling and I had no problems with those. Today though, I tried to print a simple set of 5mm cube steps in PLA. Pretty standard stuff like this http://www.thingiverse.com/thing:24238. Decided to print 3 of them at once to test accuracy of different areas of the bed and stringing problems.
Today, my print started off fine - the extruder temperature curve started off a bit janky while the perimeters were being printed but I figured it was just because the head was moving a bit of old PLA buildup inside the nozzle. It soon smoothed out into a normal, smooth, stable PID curve. So I started to browse the internet while keeping an occasional eye on the print. I'm using Repetier 1.0.6, with the default recommended PLA settings from the Rostock manual with a couple tweaks. Summarised below.
Extruder: 195°C
Bed: 60°C
Speed: 30mm/s print (200mm/s non-print)
Layer fan always on
Slow down print if layer <40s, slowest speed 8mm/s
Retraction 7.4mm, 0.2mm Z lift
After a while I noticed that there was a bit more stringing and smell coming from the extruder. Normal I figured since the print was getting into the 3rd set of steps and there may not be enough time for layers to cool.
Then I noticed there was a LOT more stringing and the print smelled very hot. Sure enough, checking the temperature graphs shows a major issue. Here's an imgur link here for the image if they don't show up properly:
[img]http://i.imgur.com/TIW3OC4.png[/img]
[img]http://i.imgur.com/dC7UPjU.jpg[/img]
Is this a thermistor problem? This doesn't seem to match the wiring issue I had when I first assembled the printer. The thermistor itself was fine but my wiring being dodgy meant that the extruder temperature occasionally went to 0 when the head moved in a certain way.
A temperature graph of what that looked like can be seen here: http://forum.seemecnc.com/viewtopic.php?f=37&t=6003
I also tried manually turning on the extruder and moving the print head around the bed at Z=50 but that did not seem to replicate the problem:
[img]http://i.imgur.com/5vrjj40.png[/img]
Extruder: 195°C
Bed: 60°C
Layer fan always on
