First Print - Still Happy
Posted: Fri Jan 09, 2015 12:16 pm
Here is my first print which failed at like 99% because I didn't get enough adhesion to the bed. So the print actually came loose and spun right at the end. I didn't get enough adhesion because i had my calibration off where the extruder was too close to the bed so the first layer was basically nothing. Can someone confirming my logic is correct?
Also there is some weird stuff going on where the layers extend out passed the previous layer on the right and left edges. They end up getting all wonky. Can anyone explain this? Heat too high? [i know it's probably obvious to most but the fan mount is flipped over and would have printed the other way]
