Advice needed for design
Posted: Sun Jan 11, 2015 6:24 am
Hi,
my RMV2 printer is currenty on its way at the Frankurt Customs department..
Anyhow, i have started designing parts for my new project.
I would be happy if somebody can give my advice if my design is printable or not, or where the problems are.
A STL file is attached.
As you can see the i have designed the infill to suite my needs best. It is a wing section for an (hopefully flying) RC model.
Dimensions are about 200x200mm, material shall be ABS.
I know that all holes are likely to be need rework.
I have created the infill in 3d design, since i need ares that are solid, and some with a very low fill grade.
I am unsure if i want to print this thing flat or upright.
I assume that flat is the best option. My fear is that i will have trouble with bridging the top layer (when printed flat).
If i print upright, i might have problems with the infill on the profile ending.....
Thank you
Thank you
