killed my onyx rev2 bed?
Posted: Sat Jan 17, 2015 8:35 pm
So I was upgrading to 24v today:
got my meanwell psu with 24V/27A (dialed it down to 20V)
a crydom 100A ssr
wired everything with 2*15AWG wires.
So everything worked fine, heated from 23°C to 95°C in about 3 minutes with bangbang-mode enabled, and therefore I did the pid autotune to switch to pid.
Problem was that my psu has a fan that is activated either when the psu gets over 50°C or when the load is above 35%. So the fan was always on and really loud when the bed was heating.
I did play around with the "Bed Pid Max Value" and dialed it down to find the sweetspot where the fan isn't always activated.
Suddenly the fan of the psu wasn't activated anymore and the bed had trouble maintaining 85°C.
I first thought I'd killed the ssr or the psu, but voltage measurement seemed right.
So I disconnected the heated bed to measure the resistance and it had 3.2 Ohm.
I then took everything apart to measure resistance directly on the solder-pads and it has 2.6 Ohm, which would be a bit high IHMO.
So is it possible that I've killed my onyx somehow?
Any suggestions?
a crydom 100A ssr
Any suggestions?
