First Print, Gaps in Extrusion
Posted: Tue Jan 20, 2015 1:27 pm
Hello All,
Noob here, just built my Rostock Max V2 this week. Loaded up Mattercontrol with the stock settings file and calibrated the machine according to the instruction manual, but I am having some major problems with my ABS prints. It seems like the extrusion is very uneven, and after watching it for a while I noticed that for the perimeters no filament comes out of the nozzle, only when the printer gets to the actual model will ABS finally start flowing, but it seems like the flow rate is waaay too low and my first layer adhesion is not good as a result. Also, it will flow for a while and stop, flow for a while and stop during the entire print, and you can hear the filament popping with air gaps constantly.
With the models I have gotten to print the plastic is choppy with irregular gaps every few millimeters. I originally though this was a z-height problem and have since adjusted both up and down i.e gripping a piece of paper so tight I can barely slip it under nozzle all the way up to the paper barely touching nozzle, but I am still getting consistently uneven flow rates. When feeding filament through manually I noticed it is initially difficult to force filament through but after a few centimeters it loosens up to the point where there is practically no resistance and the flow is totally smooth. I have felt for the amount of filament being fed during a print and it doesn't feel like filament is being fed very quickly at all, perhaps this is normal, but it seems like perhaps my extruder motor settings are wrong or the hobbed gear is not gripping correctly or tight enough.
Again this is all with the default ABS/standard quality settings straight from the website. But to be sure I have dialed up the temp to 235 and have dropped it down to 208 with no effect. On the heated bed I have tried Magic purple glue stick on the bare glass, as well as laying down a layer of kapton tape followed by glue stick and have gotten the same level of adhesion with both. Hopefully, it is just a stupid mistake I have made somewhere along the line and you all will have an easy fix for me, I appreciate any advice you can give!
