Upsilon . . . an experiment
Posted: Wed Jan 21, 2015 11:11 pm
So I'll start off by saying I love my Rostock Max. But I have to add that my printer has not been running for well over 6months with the modifications. My patience nearly ran out till just now.
As the title of this post suggests Upsilon is a method where I there are 2 inputs of filament to a single nozzle output. My original and futile attempts of getting a dual nozzle setup featured two E3D V5 nozzles along with 2 cold end extruders of my design. Everything was wired up with no problems. The issue came with alignment. The daunting tasks of making sure the heads of the nozzles were aligned, account for printer radius, adjusting towers and endstops, etc. And endless struggle of taking apart the hot end and adjusting, taking it apart and adjusting. I would come close only to get to the point where the other non extruding nozzle would knock my part off the table. Other times the nozzle dug in so close to the bed that it would mash filament into the print area. I've replaced the build plate with PEI and boro glass to improve adhesion for ABS and done a number of other mods to help. Bottom line, I've spent way too much money and time on this thing and really just need it to work.
Before folks start pointing me to places of why the Upsilon doesn't work I'll start off by saying here is where I found the idea and hopefully what saves the printer and my sanity:
http://forum.seemecnc.com/viewtopic.php?f=77&t=6081 and here http://forum.seemecnc.com/viewtopic.php ... lon#p52100
The biggest pitfall is the strings being caught in the heater block during retraction and causing a jam. I'm running ABS and HIPS only. There is no intention at this moment to be running anything different. Both seem to fair well at the same 230C temp so a temp difference shouldn't be an issue. I believe if i adjust the retraction speed and amount I might be able to control the amount of strings when retracting. If this works, and I'm crossing my fingers, then that means i only need to cal in a single nozzle. A task that is much more possible than with 2 extruders side by side.
There are a few obstacles . .
So what I need help is the pin.h and configuration.h. The trick is to get the 2nd extruder looking at the temp that is on the 1st nozzle. Can someone help me with this? I'm afraid I can easily burn something if I'm not careful.
Thanks in advance
Thanks in advance
