Max V2 Cura Repetier host settings
Posted: Thu Feb 19, 2015 8:37 pm
by shentheory
So I've been using Slic3r for a few months now, and have seen a few times that Cura often produces better slicing and prints. I downloaded the Cura standalone, but i wont lie, it was pretty daunting. I like that it slices in "Real Time", but the print settings are laid out/worded so differently than slic3r, that it will just take me a while to get use to the interface .
My question is, being that Cura is also integrated into repetier-host, would someone who uses Cura in repetier-host be willing to share their .rcp settings for the Rostock Max V2? This way I can look at the settings knowing they will work, and start adjusting things to better learn how to use Cura.
As always, much appreciated!!!!
Re: Max V2 Cura Repetier host settings
Posted: Sun Feb 22, 2015 6:32 pm
by redoverred
Here ya go, I think this is the most updated version I have so far!
Rostock Max v2.rcp.txt
RCP file - remove .txt extension
(3.22 KiB) Downloaded 1899 times
Posted: Sun Feb 22, 2015 7:42 pm
by shentheory
redoverred wrote:Here ya go, I think this is the most updated version I have so far!
you are the best!!! thanks a ton!!!
Posted: Fri Mar 13, 2015 12:17 pm
by longshot
Dumb question . . . any concerns if i plugged in your file on my regular V1 Rostock?
Posted: Fri Mar 13, 2015 2:12 pm
by 3D-Print
Thanks for the post and your settings. I've looked at Cura and it seems like a good product. I will play some more.
Posted: Sat May 28, 2016 5:45 pm
by cweiss
Do you know which version of Cura that was exported from? I'm trying to get local slicing in OctoPrint to work and am struggling with getting a functional Cura profile for the Max V2. The Cura engine in OctoPrint requires using V15.04 or earlier due to profile file format changes.
