SD card
Ziggey
SD card
Post by Ziggey »
Hey so this maybe a silly question but I'm not sure how to get my prints to the SD card. I have tried to load it from the queue but that doesn't seem to work. Also I have tried to export the print to the SD card but I have not had any luck with that either... Not sure what to do. I have been using the cable to print stuff now, but when my computer shuts off from not being used for so long it stops the print.
Ziggey
guanu
SeeMeCNC Staff
Re: SD card
Post by guanu »
Export as gcode, then copy the gcode to the sd card. when you put the card in the machine, select the gcode file and it will run
Ziggey
Re: SD card
Post by Ziggey »
Ok I will try that Thank you.
Ziggey
