				39 cm hight print
				Posted: Tue Apr 21, 2015 11:16 am
				by duvdev
				Hello
I need to print for a costumer an "aluminum" like profile 39 cm hight
I know it is at the top of the printer and very hard to do - any suggestions or tips?
thanks
				Re: 39 cm hight print
				Posted: Tue Apr 21, 2015 11:47 am
				Keep in mind that the printable area is not perfectly cylindrical. Your max Z height is only at the very center point, from there it's a cone shape down to the full diameter. Kind of shaped like a huge pencil.
You might have to cut the model up and glue it together.
				Posted: Tue Apr 21, 2015 11:50 am
				by JFettig
				You have the option to print it at an angle - stand it up but tip it a little bit. Might not be the best idea depending on how big the footprint is - you wouldn't want it to tip over in the middle of the print.
				Posted: Tue Apr 21, 2015 11:54 am
				by duvdev
				the footprint of the model 1.5 cm x 1.5 cm
and it will be palced on the center point
				Posted: Tue Apr 21, 2015 11:56 am
				by doctorgonzo
				Aspect ratio of the part also plays a huge roll, by which I mean how tall it is compared to how skinny it is. You have a crazy aspect ratio!
If the part is tall and skinny, it won't have much surface area holding it to the print bed. As the part gets taller, any force the nozzle applies to the print will multiply as the lever arm gets longer and longer. Eventually a tiny bump is all it takes to pop the part off the bed.
I'd suggest using a fairly wide skirt, maybe 15 or 20 loops (or more) around the part, to increase the amount of surface area stuck to the bed.
As previously mentioned, you might have to divide and conquer. I did that when I had to print a full length rifle stock for a customer - ended up slicing it into three parts and using dowel pins to align everything.
Chris
				Posted: Tue Apr 21, 2015 12:15 pm
				by radicaldev
				That is awesome, Chris. Got any pics? Any idea what cartridge the rifle used, and how the stock is holding up?
If that's really a viable option, I might try to make a youth stock for my Henry lever action 45 Colt.
				Posted: Tue Apr 21, 2015 12:48 pm
				by doctorgonzo
				It was a prototype for a black powder rifle made by a major manufacturer here in Atlanta. They used it to verify ergonomics, and as a trade show prop. It was never fired, never intended to be.
That one job payed for the printer and then some.
Back on topic, is there a way you can print the part laying down, in pieces? The layer orientation will be stronger but the geometry may not allow this approach.
Chris
				Posted: Fri Apr 24, 2015 6:36 am
				by duvdev
				39 cm printed just fine at the center of the plate.
