Gaps between perimeter loops
Posted: Thu Apr 30, 2015 12:06 am
I'm noticing that only in certain directions, there are gaps between concentric perimeter loops. i.e. lines along the Y-axis. Photos: http://imgur.com/a/pRT6o
Other print defects:
- nut pockets are not properly shaped hexagons. They are longer in some directions than others.
- layer alignment is off near beginning, then evens out later
E3D Volcano, 0.8mm nozzle, 0.6mm layer height.
Sliced with Slic3r at 1.2mm extrusion width, 30 mm/s, 3 loops, external perimeters first.
PLA @ 220 C, (bed at 42 C)
Any idea on how to remedy these problems?
All u-joints lubed with Tri-Flow (PTFE-based dry lube). Belts are tightened pretty much as far as esbowman's belt tensioners will allow. In fact, there seem to be belt grinding noises and some black crumbs, but better tight than allowing slop, right?
http://youtu.be/QyA0mZ66-Rc
I noticed a fair amount of slop in the effector platform. Installing rubber bands didn't seem to really change that.
https://youtu.be/ML-ELfqjaiM
