PEEK fan installation causes temp error on Max v2?
Posted: Sat May 02, 2015 1:00 pm
Hello! I'm almost done with assembling/calibrating my new Max V2 and I've hit a weird snag.
I successfully printed the two fan shrouds and installed them. First time turning on power, the PEEK fan turned on immediately, which shouldn't happen - hot end wasn't turned on yet. Printer display and MatterControl both reported a temp of 236 deg C, and then the printer display for temp (both hot end and bed) changed to "def". Tried to run the PID auto-tune - terminal window said "Error: PID autotune failed! Temperature too high."
Everything was working fine before I installed/connected the fans. In fact, before I wired the fans, I tested to make sure I hadn't screwed up the hot end while installing the fan shrouds, and it extruded ABS just fine. Wired the fans into the circuit, turned the printer on, and got the results described above.
Did I miss something? Please advise!
