I need help!
Posted: Fri May 08, 2015 9:48 am
by HighDangerr
Hi guys!
i have a problem with my print
. after a hour of printing this happens. you see it at the pictures.
http://imageshack.com/a/img540/6686/6HoaPX.jpg
http://imageshack.com/a/img537/5189/LzSQ4u.jpg
Does anyone know what the problem is ? and how i can solve this?
Re: I need help!
Posted: Fri May 08, 2015 12:59 pm
by Earthbound
Can you give more detail about what problem is occurring? White material makes it difficult to see much detail.
I think I see that the layers begin to offset to one side.
When this occurs, is the part still anchored to the bed?
Re: I need help!
Posted: Fri May 08, 2015 1:50 pm
by HighDangerr
yeah the layers are beginning to offset to one side.
And the part is still anchored to the bed!
i'm printing on blue painters tape
Re: I need help!
Posted: Fri May 08, 2015 3:20 pm
by Earthbound
Consider how the object was oriented on the bed while it was being printed.
Is the offset directly toward or directly opposite one of the towers?
Offsets are the result of lost motion or steps. If the offset is aligned with one tower, that is the first place to look. A loose belt or loose pulley is the most likely cause.
If everything looked really good for many layers, then suddenly offsets, the problem may be the sleeved wires/tube snagging on an arm after the head reaches a critical height.
Have you tried printing this part more than once? Did it fail the same way each time? Observing it as the failure occurs can be valuable in determining the cause. Unusual sounds or sudden jerky motion are important clues.
Re: I need help!
Posted: Sat May 09, 2015 5:18 am
by HighDangerr
i've printed it 2 more times. and it didn't fail at the same time.
also when it happens the nozzle is hitting the object.
so i think the nozzle lowers a bit, but i don't know why.
