Rostock MAX is alive (almost)
Posted: Wed Sep 05, 2012 12:17 pm
by johnoly99
So, you guys have been guessing what we've been up to, here it is. The Rostock MAX is almost done
http://reprap.org/wiki/Rostock_MAX
We brought the arm mechanisms to life yesterday, proving the cheapskate would work awesome! Now, we're just finishing up some of the parts/pieces for the arms, and we're already cutting the molds for the injection molded platform and arms. Hopefully, I'll be on Ustream all weekend showing it off and printing. It might be early next week before we're printing, but we'll see!
Go take a look and see what you guys think,
Re: Rostock MAX is alive (almost)
Posted: Wed Sep 05, 2012 3:42 pm
by johnoly99
Also go check it out on thingiverse.com
http://thingiverse.com/thing:29762
Posted: Wed Sep 05, 2012 5:02 pm
by jbinion
You beat us to it.....But it looks great.
Posted: Wed Sep 05, 2012 5:55 pm
by Eric
As a concept, it has a lot of cool factor.
What are the pros/cons of this kind of 3-point positioning system compared to the more traditional XYZ approach?
Posted: Wed Sep 05, 2012 6:12 pm
Delta robot have very low moving mass that means the potential for very high speeds, which is attractive for printing.
On the downside with a linear configuration like the Rostock you need a lot of vertical height to get the necessary travel.
Posted: Wed Sep 05, 2012 7:54 pm
by timothysvec
Sweeeeet. Look forward to seeing that thing running.
cheer's tim
Posted: Thu Sep 06, 2012 1:31 pm
by timothysvec
How do you think your board and driver's will hold up when you use nema 23's? If they don't... geko 540 and mach3. I know that the $75.00 4 axis board has had problem's, when used with small cnc milling machines.
Posted: Thu Sep 06, 2012 1:37 pm
by johnoly99
Tim, the Rostock MAX uses NEMA 17's. And, as of right now, I'm unaware of Mach3 being able to handle the delta positioning. I've heard EMC2 on Linux does, but not Mach (not yet!)
Here's a quick clip for you guys to take a peek at
http://www.youtube.com/watch?v=nhqgu5sYLQM&feature=plcp
Posted: Thu Sep 06, 2012 4:03 pm
by timothysvec
That is so cool! Is your extruter going to be located down on the business end or on the side......and I have to comment on what's propped up in the corner behind you guy's. Proper complaint department problem solver?
Posted: Thu Sep 06, 2012 4:36 pm
by johnoly99
Oh tim, you noticed our complaint dept. eh?
Bowden extruder, but using our "Steve's extruder" with a modification to use push-to-connect fittings
Posted: Thu Sep 06, 2012 5:24 pm
by Eric
johnoly99 wrote:Oh tim, you noticed our complaint dept. eh?
Which implies that eventually you will be able to offer a Bowden upgrade for any Steve's extruder, no matter what printer it's on?
Posted: Thu Sep 06, 2012 5:54 pm
by johnoly99
Yup!
Posted: Thu Sep 06, 2012 7:15 pm
by jbinion
Where did you get the Cheapskate linear slide?
I have some hardened steel pars about 4 foot long that should work.
jim
Posted: Thu Sep 06, 2012 10:06 pm
by kilroyo
WOw!! that thing is beautiful .... and huge .. But the price , any chance you guys going to be offering an el-cheapo bargain build kit? Trying to figure out how I can sneak this one past the wife is going to be tuff
Posted: Mon Sep 10, 2012 8:35 pm
by timothysvec
Just for laugh's....could you please show this to some mastercam people..........
cheers,
tim
Posted: Tue Sep 11, 2012 6:18 am
by johnoly99
Chad at cas cam tech (our mastercam dealer) was wqmting to maybe work on a toolpath dll for printing. Hahah
Posted: Tue Sep 11, 2012 10:36 am
by timothysvec
sweeet!
Posted: Thu Sep 20, 2012 4:01 pm
by tom10122
Nice, Do you guys ever think that you will build a printer/cnc that uses threaded rods instead of belts? I saw that a group is designing one that used trapezoidal threaded rods for more movement per steps and it looked pretty cool.
Posted: Thu Sep 20, 2012 4:13 pm
for something moving relatively light weights, with no side loads, belts are a really good solution, they can be tightened to provide effectively 0 backlash, and they are much more "efficient" than anything short of a ball screw.
There is the additional advantage in the reprap space because speed is important and belts with pulleys are generally in the 0.5 to 1 TPI range.
To do the same with screws, you need expensive screws with multiple starts to get close to the same TPI, and to get rid of backlash you either need acme screws with matched delrin nuts, or a pair of nuts/screw with some preload between them.
If you were going very large it might be worth it, or if you wanted something that could act as a light milling machine.
There is a company called Qube that is making a printer/milling machine that uses replaceable custom leadscrews, you use the Low TPI screws when printing and swap to the higher TPI screws if you want to mill something trading speed for torque, but AFAIK it's still not available.
Posted: Thu Sep 20, 2012 4:57 pm
by tom10122
Polygonhell wrote:for something moving relatively light weights, with no side loads, belts are a really good solution, they can be tightened to provide effectively 0 backlash, and they are much more "efficient" than anything short of a ball screw.
Hmm Well I was thinking that there would be no having to adjust the belts, Didn't know it had backlash though, I was thinking of the Makibox, the only competitor really for the H-1 Pricewise
Posted: Fri Sep 21, 2012 11:50 pm
by johnoly99
Or? What if you had a gearbox, where in one configuration, your motor pulley is X teeth, and your screw pulley is Y teeth, and that provided 4:1 reduction for torque. And, let's say maybe, perhaps, it was easy as pie to maybe? oh, dunno, loosen a setscrew on those same pulleys, and put Y pulley on the motor, and oh my! Put X on the screw, and BAM, you now have 4:1 increase in your drivetrain? Although, you'd prob. not need to do that swap in Z, just X and Y.
FYI, quick change rear-ends in the race cars I'm involved with have similar principles. Each pair of gears has two possible gear ratios, the input and output shafts of the rear ends are fixed, and the tooth count on the gears create the mesh. Too bad gears have backlash, otherwise skip the belts?
Posted: Wed Sep 26, 2012 8:04 pm
by BrainSlugs83
If you're worried about backlash with gears, have you considered using a
Herringbone gear? All the cool kids are using them.
[img]
http://thingiverse-rerender.s3.amazonaw ... w_card.jpg[/img]
