Y tower not calibrating.
Posted: Mon Jun 15, 2015 11:36 am
So here is the situation. I moved, but before I moved I would like to let you know that I was getting beautiful prints and I couldn't have been happier
! Then I moved I put my printer in the car a laid it on its side, because its so big.... I put some towels on the inside so nothing would get banged around. or if something magically fell on my printer, it wouldn't hit my hotend and break it. So I get it to my new house and one of the metal clips off the endstop switches broke off( Y Tower)
. I ordered a new one from where seeme cnc recommended. installed it and figuring it should get calibrated from the moved I did that. Then I went to print. And something weird happened. Around the X tower was fairly good for the first layer but when it started to rise when it went to the Y tower. From the Y tower to the X tower it lowered again but its still to high.
Here is how high it is on the towers:
Z - good, little resistance on paper. Prints fine there.
Y - 1/4 inch easy if not a little more
X - About 3 mm, Not low enough to print correctly.
X-Z touches my PEI sheet. (to low)
I have tried to calibrate automatically and manually( using the screws) and these methods do not help lower the Y axis. I had the Y screw one turn from being out and it didn't help....
Any suggestions??
Thank you,
ZIG
Any suggestions??
Thank you,
ZIG
