Big size printer - help needed
Posted: Sun Jun 21, 2015 3:08 pm
by duvdev
Hello
I built a bit size printer. rod length of 60cm
what are the changes in the eeprom that I need to make? and what are the clibration values of the scriptes?
thanks
Re: Big size printer - help needed
Posted: Sun Jun 21, 2015 5:30 pm
by bubbasnow
does it have the same bed? same tower distance? same effector? same carriages?
Posted: Mon Jun 22, 2015 10:22 am
by duvdev
Hi, thanks for the help.
the bed size is 120 cm ( 60 radius ) the arms lenth is 600 cm and the max hight is 1.2 meter.
the effector and carriages are the same.
Posted: Mon Jun 22, 2015 5:18 pm
by teoman
What? 6m arms?
I am sure you have all of us intrigued, mind posting a few pictures?
You would defintely have to go over the software. Are you using a RAMBO?
Posted: Mon Jun 22, 2015 5:50 pm
by KAS
Yea, I would think your max height should be a bit taller to match those arms. :)
Posted: Tue Jun 23, 2015 2:12 am
by bot
I think it's 600mm, which is still huge... so I'd love to see pics. :)
Posted: Tue Jun 23, 2015 6:01 am
by duvdev
hi
it was ment to be 600 mm ( 60 cm )
I am starting to calibrate it.
any changes in eeprom?
i will upload pics later
Posted: Tue Jun 23, 2015 6:22 am
by teoman
Yes there will be changes in the software AND the eeprom.
Arm length, and bed diameter for one. What effector platfomr are you using? That also has an effect on the bed size. Bubbasnow has previously done something similar.
Posted: Tue Jun 23, 2015 6:29 am
by duvdev
arm length changed.
where is thr bed diameter?
stock effector platform
