Extruder wont push filament
Posted: Fri Jun 26, 2015 6:45 pm
by dsl158
When I use matter control 1.2 to control the extruder the motor spins left and right over and over. very little filament comes out
https://www.youtube.com/watch?v=TodOAI_ ... tion=share
Re: Extruder wont push filament
Posted: Sun Jun 28, 2015 10:58 am
by BenTheRighteous
Do you have your filament multiplier on the LCD set to anything other than 100%?
Posted: Sun Jun 28, 2015 12:36 pm
by dsl158
BenTheRighteous wrote:Do you have your filament multiplier on the LCD set to anything other than 100%?
No its at 100
Posted: Sun Jun 28, 2015 5:46 pm
by dsl158
Posted: Mon Jun 29, 2015 1:45 am
by Dale Eason
That usually is caused by poor or incorrect connections of the stepper motor wiring. Looks like at least one phase is not connected.
Dale
Posted: Mon Jun 29, 2015 12:54 pm
by dsl158
Dale Eason wrote:That usually is caused by poor or incorrect connections of the stepper motor wiring. Looks like at least one phase is not connected.
Dale
I checked all the connections and still nothing
Posted: Mon Jun 29, 2015 1:46 pm
When you say spins left and right, does it move in the commanded direction consistently or does it alternate/vibrate?
Posted: Mon Jun 29, 2015 2:29 pm
by dsl158
Polygonhell wrote:When you say spins left and right, does it move in the commanded direction consistently or does it alternate/vibrate?
http://www.youtube.com/attribution_link ... load_owner
It does it when it has to extrude or retract
Posted: Mon Jun 29, 2015 2:57 pm
by KAS
Someone else was having that kind of movement. I'll try to find that post to make sure it's the same issue.
Posted: Mon Jun 29, 2015 3:01 pm
That's a bad connection on the stepper circuit somewhere, or the stepper is mis-wired.
I had it happen when I had in inline connector on the motor wires, the connection looked good, but was just poor enough that one of the lines had intermittent connectivity.
I would start by looking at the crimped connector at the RAMBO board, a poor crimp on one of the pins or badly seated pin in the connector would be enough to do it.
Of course could be a bad stepper driver as well, but that's much less likely.
Posted: Mon Jun 29, 2015 3:08 pm
by KAS
Just hook that extruder up to X axis and try to home the towers. If it works, then most likely is a connection issue. (Polygonhell's suggestion above)
You can also put the x axis stepper on the extruder port, just be careful and hover the power button before it hits something.
Also, check your endstop switch wires aren't touching the stepper wires.
Posted: Mon Jun 29, 2015 3:10 pm
by KAS
bah, just found it
Re: how do I wire extruder motor?
Postby AndyB ยป Sat Feb 14, 2015 2:00 am
I had to wire them into the connector exactly like the order on the other connectors. The manual is wrong. I just did this a week ago. If the extruder shakes back and forth, you wired it incorrectly. The order I used was red, green, white, black, which would make the picture on the build guide (Figure 16-25 on page 189) wrong.
http://forum.seemecnc.com/viewtopic.php ... rth#p67954
