Fried Heat Bed Terminal
Posted: Mon Jul 06, 2015 5:39 pm
Greetings from Colorado!
The heat bed of my Rostock Max V2 suddenly stopped heating up. When I took off the bed, I noticed that a bit of tape had come loose, and the thermistor signal wires were shorting. Then, I checked out the RamBo and saw this:
Ouch
. Luckily, everything else still works and the board itself does not appear to have sustained any physical damage. Is there an easy way to replace the terminal block? Or should I just cut my losses and get a new RamBo?
Sreyas
Ouch
Sreyas
