Dialing things in
Posted: Tue Jul 14, 2015 10:27 am
Rostock Max V2, 2 1/2 days of print time, this is my first 3D printer.
First off, I've had successful prints right from the start. I do like to tinker though, and I'm chasing a higher quality finished part then I am getting at the moment.
Everything is leveled well and running fine for the most part, but I may be confused on certain settings, and the order in which to do them.
I've adjusted rod length, so that I now get correctly sized parts.
Settings are .5 nozzle, .4 first layer height
I had a great first layer, but my single wall thickness was 0.8mm. When I used the extrusion multiplier to bring single wall thickness to .60mm, I have large gaps in 100% layers. First or last. In the below picture, the box on the left is adjusted to .60mm walls, the right is adjust for good layer coverage, but results in fat walls.
[img]https://goo.gl/photos/62sST1wkUiYUSLTJA[/img]
Is there a way to get both the recommended extrusion width, and good full layers?
I've also noticed paired lines, where slack somewhere in the system is causing a bunch up then gap out situation, exasperating the situation.
