Extruder Musings
Posted: Thu Jul 23, 2015 10:34 am
I’m tired of playing around with retraction distance, retraction speed, coasting at the end of a loop, and nozzle temperature, all in an effort to get rid of PLA stings. I’ve also played with lowering the current setting for the extruder stepper in the configuraition.h file. This helped, but it is still not enough. My steppers are all “Automation Technologies” brand. It may be that my PLA is has soaked up moisture but if that’s the case, that will be my typical situation anyway so I need to be able to print with it. (I stored it in a sealed bag with silica baggies, but I live in the tropics so it is exposed on top of the printer for however many days I am using it.) I also tried MHackney’s PLA settings and they did nothing for me. And I don’t see myself going the canola oil route.
The issue is I have an upper limit on retraction distance and speed since high values here result in a hot stepper motor that eventually chews-up the PLA. So to deal with the extruder motor temperature I have a few options:
1. Attach a fan to the extruder motor – The obvious choice. I would need to find a suitable size 12V fan and mount. Also possibly add heatsinsks to the motor while I’m at it. And I'm not hot on the idea of tapping into the PEEK fan wires. Any suggestions for going this route would be welcome.
2. Buy a geared stepper – If I understand correctly the gearing is to lower the speed and increase the torque. Which means if the motor overheats because it is trying to punch above its torque this would help, and I expect the quality of the prints would improve due to increased resolution in the motor steps. But if it is overheating because of the long and speedy retractions, then it would be worse off as it now needs more/faster revolutions to make retracts. Then again, if my Automation Technologies motor is overheating simply because it is a crappy motor, then any higher quality motor will result in an improvement anyway. I'd need to deal with printing or designing mounts and having to find suitable fasteners.
3. A more aggressive hobbed gear – Like the canola oil, this does not make sense, but I would love to see what effect it has. It would have certainly helped with a cheap ABS I was using for which I had to add a spacer on the spring to increase the spring tension. I wonder if this would be a drop-in replacement for RMV2 hobbed gear.
http://www.typeamachines.com/collection ... 3-series-1
I’d love to hear the community’s thoughts.
