Hot End Temp issue...
Posted: Thu Jul 23, 2015 12:55 pm
so just to start I did search for hot end issues but the data I've gathered doesn't match anyone elses issues so I'm asking for help.
Here is the situation: I did a print last night, took about 70 minutes, came out just find and looked good. It finished. I set the preheat settings to maintain the hotend and bed temps so I could print again right away. I noticed that the hotend temp was at 197 and change when it was supposed to be at 230. So I reset the printer connection and hit the preheat button and still only went to the 197 range.
I then went searching this forum and found similar issues involving miss-configured PID's so I went through the following steps:
1. let the hot end cool completely
2. set the preheat to 50 and the temp came up to 50 and held
3. set the preheat to 70 again it came up to temp
4. set the preheat to 100 again it came up to temp
5. set the preheat to 150 came up to temp but took it longer than I felt it should have
6. set the preheat to 170 as above came up just took longer than expected
7. set the preheat to 200 and only made about 193
8. set the preheat to 245 and temp made it to 210
So i thought this might be the PIDs, so I did a calibration and it came up to 200 as specified and adjusted the PIDs in the EPROM. Still getting the same results.
It feels like the hotend isn't getting enough power(I have nothing to back this up, just gut feeling). One observation that I did have is that when both the bed and hotend heaters are running the LED ring I have on the end effector usually has a faint pulse that coincides with one of the LEDs on the Rambo that blinks...that wasn't happening anymore. The LED on the Rambo was blinking, but not seeing the variation at the LED ring.
Any help would be greatly appreciated!!
