Can no longer home Rostock Max v2
Posted: Fri Aug 14, 2015 7:53 pm
by Hornbrook
Hello,
I've had my printer for about a week and all was well until I had to go away for a couple of days. On my return I could not get a print to complete. The hot end would grab a bit of excess and start to smear the print around the bed.
I thought I might need to recalibrate the z axis and set about doing that and, at some point, when I pressed HOME the hot end went straight to the bed. Ouch. I had to change the setting for the end stops when I first assembled the printer as I had the different type of end-stop plugs. I thought the printer had reverted to the original settings and went back into the Repetier.ino and changed them again.
I then tried to calibrate the z axis and when I Pressed Home it moved up a short distance, not quite to the end stops and when I pressed HOME again, it started grinding into the end stops.
I searched around the forum and tried a few suggestions and nothing seems to help. I'm lost right now and could use some suggestions as to what I might try next.
Thank you!
Re: Can no longer home Rostock Max v2
Posted: Fri Aug 14, 2015 9:00 pm
by KAS
Will each towers end-stop switch register a correct value for each location when running the M119 command from the terminal?
Page 249 of the manual: http://download.seemecnc.com/rostockmax ... dition.pdf
Posted: Fri Aug 14, 2015 9:40 pm
by Hornbrook
Hi Kas,
Yes, it does register the correct values.
Posted: Sat Aug 15, 2015 7:45 pm
by Hornbrook
Solved problem. I went back to, erase eeprom, and went from there in the guide. Thanks!
Posted: Sun Aug 16, 2015 2:52 pm
Hornbrook wrote:Solved problem. I went back to, erase eeprom, and went from there in the guide. Thanks!
I am glad you got it solved! Good work.
