Problems with extruding
Posted: Sun Aug 16, 2015 3:08 pm
I've got a Rostock Max V2 here and I'm having terrible problems printing anything! It worked just fine for one or the other right at the beginning but now I have nothing but trouble printing. More specifically, my extruder can't create enough force to get the ABS thru my hot end which I set to the max temperature of 240°C. While printing I hear a constant clicking coming from the extruder - The filament is popping back up and or eating holes into the filament!
A friend suggested it could be the bowden tube which is causing a lot of resistance, but when I unscrew the tube fitting from the hot end there is no force needed to operate the extruder. I did notice however, that the ABS filament is getting stuck in the PTFE tube inside the hot end. The diameter of the filament which is getting stuck inside the tubing is 2.15mm in thickness (My filament is pretty much 1.75 unmelted) and the tube itself has an inside diameter of ~2.0mm. I do understand that when heating the hot end, the tube inside will expand.
I'm pretty sure that the hot end is up to temperature, as if I hold some plastic against my 0.75mm nozzle, it will melt as you would expect it to without any force applied!
I'm not sure if the problem lies with my hot end or if I'm looking in the wrong place.
