Printer is trying to print outside the print area
Posted: Tue Oct 27, 2015 10:07 am
by thomasrotten
Hi there
I have finally finished my build of my rostock max printer
I not have this problem....
In 3D view everything seams fine but if I click Layer view you can see that the printer is gonna print the item outside the print bed...
Anyone with a good solution??
regards thomas
Re: Printer is trying to print outside the print area
Posted: Tue Oct 27, 2015 11:21 am
by stonewater
do you have center on bed enabled in mattercontrol ?
Tom C
Posted: Tue Oct 27, 2015 11:57 am
by thomasrotten
Where can i find that setting??.. I have tried now for half an hour to find that
Posted: Tue Oct 27, 2015 4:38 pm
by IMBoring25
Is this the latest MC and which slicing engine are you using?
Posted: Tue Oct 27, 2015 4:49 pm
by thomasrotten
yes it is the latest mc version.. slicer engine is the default one...
Posted: Tue Oct 27, 2015 4:50 pm
by thomasrotten
I googled the center on bed option but i don“t have the choice under output options...
Posted: Tue Oct 27, 2015 5:48 pm
by KAS
I don't have MC installed so I don't know if this is the correct location with the newest version.
From the MC wiki:
General
Size and Coordinates
Bed Size: These values determine how long your bed is along each axis, by millimeters.
Print Center: These values determine where the center of your bed lies.
Build Height: How high your bed can lower or raise, along the Z axis.
Bed Shape: This determines the shape of your bed, either rectangular or circular.
Posted: Tue Oct 27, 2015 5:58 pm
by stonewater
its under settings / print/output options/ center print
Tom C
Posted: Wed Nov 04, 2015 3:08 pm
by Nath5
The current version of matter control seems to not play nicely with slic3r I was having the same problems. You can either use the matter slicer or use slic3r standalone toe generate the gcode and then open that in matter control.
