Help please, weird non-homing/reversed X carriage?
Posted: Mon Nov 02, 2015 7:09 pm
Not exactly sure how to describe what my problem is, so I made a video. I was almost finished calibrating / adjusting endstops and HR after swapping to longer arms (~295.2 mm). The Z and Y macros were spot on and so was the X the first time I hit it, but after adjusting its endstop and hitting home to check the new height, the carriage started going the wrong way. I shut it off and reset the positions manually, and well you can see in the video.... (i had some trouble getting the embed to work so heres the url: https://youtu.be/K4zuTsili08 )
[youtube]https://youtu.be/K4zuTsili08[/youtube]
Im running Repetier 91s and everythings stock except the arms and hot end. HR is currently at 129.85 or so I originally started at 140 and have worked my way down. The prior iteration at 130.2 was almost good and everything went smoothly.
Any help is appreciated. Thanks !
Tyler
UPDATE... after re watching the video i realized my x tower endstop is probably stuck on and thats probably the whole problem..... agreed? again thanks!
Tyler
