Filament sticking to nozzle.
Posted: Mon Nov 16, 2015 12:57 pm
Hi community,
I was wondering if you could help me with an issue I've been having with my v2.
The main issue I'm having is that the filament is sticking to the nozzle rather than the heat-bed. I am using ABS.
I set up the printer with vanilla settings outlined in the manual first time round (first calibration method), and got a good print for the fan shroud, until it failed a couple of layers from the top, so at least I know the machine is capable of it!
By what was left of the filament mess I assume at some point the ABS didn't stick to the layer below and at that point the filament just built up on the nozzle. The nozzle temp is currently set to 230°C.
Since then, I have been unable to print without build-up on the nozzle. To fix this, I have;
> Changed the temperatures of the bed up to 80°C,
> Replaced the glue stick with kapton tape as suggested by someone else on the forum,
> Recalibrated using method 2,
> Further lowered the Z height manually bit by bit, with no effect on the printing.
I am not sure what the next step in fixing this is, I don't wish to do something I'll end up regretting.
Hope you can help,
Memph.
Hope you can help,
Memph.
