So, I changed the nozzle to 0.35mm...
Posted: Mon Nov 16, 2015 10:56 pm
by Agisis
...and updated the quality setting for one of my configurations to use 0.35mm nozzle size. When I print, it prints in lines (meaning spaces between each row on the bottom layer) as though it has a 0.5mm nozzle even though the nozzle is 0.35mm and the settings are correct. I have printed in 0.35mm before and this did not happen. Anyone have any ideas? (Nozzle Diameter is set to 0.35). This is very very confounding and makes it a bit of a struggle obviously to produce fine quality prints
Re: So, I changed the nozzle to 0.35mm...
Posted: Mon Nov 16, 2015 11:11 pm
by IMBoring25
Which slicer? Are you slicing in a host software or a standalone slicer? Are all the other settings identical with the previous configuration?
Posted: Mon Nov 16, 2015 11:41 pm
by Agisis
using standard slicer. no changes to anything at all, just nozzle. I usually make a duplicate of whatever configuration I have set up and name it with the nozzle size (I.e. MH-Black-PLA-0.35mm-Fine for example). very weird stuff and I don't like weird especially when I've done lots of nice prints with 0.35mm in the past. I also noticed my eeprom settings for the horizontal radius and rod lengths were reset somehow back to the original values so I had to recalibrate the whole thing. It still gave me lines with spaces between them as though it was thinking it was 0.5mm instead of 0.35mm. I upgraded MC just in case, no luck. I also thought maybe it was because I scaled my model and perhaps it scaled it with 0.5mm in mind and when I switched to 0.35mm it didn't reslice or something, but starting over didn't help either.
Posted: Tue Nov 17, 2015 12:12 am
by Agisis
I wonder..when you change nozzle diameter, shouldn't the extrusion rate change as well automatically?
Posted: Tue Nov 17, 2015 12:14 am
by IMBoring25
It should.
If you lost your EEPROM, I'd look into recalibrating your extruder steps/mm.
Posted: Tue Nov 17, 2015 2:44 am
by teoman
I remember seeing a setting for first layer width.
And when i applied that my first layers were much wider extruded. But on the thread i was following it was mentionned that this was not really good for bed adhesion so i abandonned that approach and cannot remember much.
I think it was something called first layer extrusion multiplier.
This was in matter control/slice.
Posted: Tue Nov 17, 2015 3:55 am
by teoman
Is this for all layers?
Posted: Tue Nov 17, 2015 4:55 am
by Agisis
seems to be happening for all layers.
Crap, the tornado sirens are going off. got to go! (In Dallas TX)
Posted: Tue Nov 17, 2015 8:32 am
Well hopefully the tornado didn't get you. :)
One thing people forget (or simply don't know) is that has your nozzle diameter decreases, so must your print speed. When I run a .35 nozzle, I keep the print speed round 30mm/sec or less. You also need to make sure you've told your slicer what the new nozzle diameter is.
Posted: Tue Nov 17, 2015 3:23 pm
by Agisis
No tornado got me. heh. I can try lowering the print speed and I am curious to try it with a higher extrusion rate. The slicer configuration setting I am using has it set to 0.35mm for nozzle size and it shows up in the display. I will try again later tonight and post a pic of it if it is still happening.
Posted: Tue Nov 17, 2015 8:20 pm
by Agisis
It's starting to look like it might have been the way the slicer was chopping up the model. I printed some another set of objects tonight and it did not exhibit the same issues. very weird!!!
