Weird Stepper Motor Behavior
Posted: Wed Nov 18, 2015 11:52 am
by Bishop
Guys,
So far I have not been able to find anything on the Internet discussing my current issue, so I'm looking to the experts (yes, I mean you) for some guidance.
My rig is a Rostock MAX V2 (w/o injection molded carriages) that I have had for about a year. Recently I upgraded to the latest version of the Repetier Firmware (0.96.2) and got everything fully functional...or so I thought. Being a developer, I understand the risks with upgrading. Since I only run Linux at home, and can't get MatterControl to stay up for more than a few minutes without crashing (bug reported and entered into their system), I really don't have much of a choice.
Current state of my printer is that all of the end stops are working and reporting properly; all motors move smoothly in the correct directions; hot end heats up and reports temps correctly; same with the heated bed; and fan control works properly.
Here's my issue: After heating either the hot end or bed or both, the stepper motors start to move erratically after a few minutes of operation. Sitting idle, but engaged while heated the stepper motors will start to 'hiccup'; move ever so slightly in once direction and immediately reverse back to original position. If I move the effector platform while in this state it will skip around and never ends up the the proper location. If I disengage the stepper motors, the problem goes away, but only for a minute or two after the first effector move.
This behavior is seen when controlling the printer via Repetier-Host OR directly through the RAMBo via the LCD UI controls. If I don't heat the printer, it seems to go for hours without displaying this issue.
Here are the contents of my current Configuration.h file.
    This file is part of Repetier-Firmware.
    Repetier-Firmware is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    Repetier-Firmware is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
/**************** READ FIRST ************************
   This configuration file was created with the configuration tool. For that
   reason, it does not contain the same informations as the original Configuration.h file.
   It misses the comments and unused parts. Open this file file in the config tool
   to see and change the data. You can also upload it to newer/older versions. The system
   will silently add new options, so compilation continues to work.
   This file is optimized for version 0.92
   generator: http://www.repetier.com/firmware/v092/
   If you are in doubt which named functions use which pins on your board, please check the
   pins.h for the used name->pin assignments and your board documentation to verify it is
   as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 301
#include "pins.h"
// ################## EDIT THESE SETTINGS MANUALLY ################
#define MICROSTEP_MODES { 16, 16, 16, 16, 16 } // [1,2,4,8,16]
#define MOTOR_CURRENT_PERCENT { 175, 175, 175, 200, 0 }
// ################ END MANUAL SETTINGS ##########################
#define FAN_BOARD_PIN -1
#define BLUETOOTH_SERIAL  -1
#define BLUETOOTH_BAUD  115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define AXIS_STEPS_PER_MM 80
#define XAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
#define YAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
#define ZAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
#define EXTRUDER_FAN_COOL_TEMP 50
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define DECOUPLING_TEST_MAX_HOLD_VARIANCE 20
#define DECOUPLING_TEST_MIN_TEMP_RISE 1
#define KILL_IF_SENSOR_DEFECT 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_START_COMMANDS ""
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 92.65
#define EXT0_TEMPSENSOR_TYPE 8
#define EXT0_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT0_HEATER_PIN HEATER_0_PIN
#define EXT0_STEP_PIN ORIG_E0_STEP_PIN
#define EXT0_DIR_PIN ORIG_E0_DIR_PIN
#define EXT0_INVERSE true
#define EXT0_ENABLE_PIN E0_ENABLE_PIN
#define EXT0_ENABLE_ON false
#define EXT0_MAX_FEEDRATE 100
#define EXT0_MAX_START_FEEDRATE 45
#define EXT0_MAX_ACCELERATION 6500
#define EXT0_HEAT_MANAGER 1
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MAX 255
#define EXT0_PID_INTEGRAL_DRIVE_MIN 60
#define EXT0_PID_PGAIN_OR_DEAD_TIME 23.93333
#define EXT0_PID_I 3.413333
#define EXT0_PID_D 41.92333
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_ADVANCE_BACKLASH_STEPS 0
#define EXT0_WAIT_RETRACT_TEMP 150
#define EXT0_WAIT_RETRACT_UNITS 0
#define EXT0_SELECT_COMMANDS "M117 Extruder 1"
#define EXT0_DESELECT_COMMANDS ""
#define EXT0_EXTRUDER_COOLER_PIN 7
#define EXT0_EXTRUDER_COOLER_SPEED 255
#define EXT0_DECOUPLE_TEST_PERIOD 12000
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_LONG_LENGTH 13
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_EXTRA_LENGTH 0
#define RETRACTION_UNDO_EXTRA_LONG_LENGTH 0
#define RETRACTION_UNDO_SPEED 20
#define FILAMENTCHANGE_X_POS 0
#define FILAMENTCHANGE_Y_POS 0
#define FILAMENTCHANGE_Z_ADD  2
#define FILAMENTCHANGE_REHOME 1
#define FILAMENTCHANGE_SHORTRETRACT 5
#define FILAMENTCHANGE_LONGRETRACT 50
#define JAM_STEPS 220
#define JAM_SLOWDOWN_STEPS 320
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define RETRACT_DURING_HEATUP true
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 100
#define NUM_TEMPS_USERTHERMISTOR0 0
#define USER_THERMISTORTABLE0 {}
#define NUM_TEMPS_USERTHERMISTOR1 0
#define USER_THERMISTORTABLE1 {}
#define NUM_TEMPS_USERTHERMISTOR2 0
#define USER_THERMISTORTABLE2 {}
#define USE_GENERIC_THERMISTORTABLE_2
#define GENERIC_THERM2_T0 25
#define GENERIC_THERM2_R0 100000
#define GENERIC_THERM2_BETA 4037
#define GENERIC_THERM2_MIN_TEMP -20
#define GENERIC_THERM2_MAX_TEMP 300
#define GENERIC_THERM2_R1 0
#define GENERIC_THERM2_R2 4700
#define GENERIC_THERM_VREF 5
#define GENERIC_THERM_NUM_ENTRIES 33
#define HEATER_PWM_SPEED 0
// ############# Heated bed configuration ########################
#define HAVE_HEATED_BED true
#define HEATED_BED_MAX_TEMP 100
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_SENSOR_TYPE 98
#define HEATED_BED_SENSOR_PIN TEMP_1_PIN
#define HEATED_BED_HEATER_PIN HEATER_1_PIN
#define HEATED_BED_SET_INTERVAL 5000
#define HEATED_BED_HEAT_MANAGER 1
#define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255
#define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   42.92333
#define HEATED_BED_PID_IGAIN   0.736667
#define HEATED_BED_PID_DGAIN 625.89
#define HEATED_BED_PID_MAX 255
#define HEATED_BED_DECOUPLE_TEST_PERIOD 300000
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 260
#define MIN_DEFECT_TEMPERATURE -10
#define MAX_DEFECT_TEMPERATURE 290
// ##                             Laser configuration                                      ##
If the firmware is in laser mode, it can control a laser output to cut or engrave materials.
Please use this feature only if you know about safety and required protection. Lasers are
dangerous and can hurt or make you blind!!!
The default laser driver only supports laser on and off. Here you control the eĆ­ntensity with
your feedrate. For exchangeable diode lasers this is normally enough. If you need more control
you can set the intensity in a range 0-255 with a custom extension to the driver. See driver.h
and comments on how to extend the functions non invasive with our event system.
If you have a laser - powder system you will like your E override. If moves contain a
increasing extruder position it will laser that move. With this trick you can
use existing fdm slicers to laser the output. Laser width is extrusion width.
Other tools may use M3 and M5 to enable/disable laser. Here G1/G2/G3 moves have laser enabled
and G0 moves have it disables.
In any case, laser only enables while moving. At the end of a move it gets
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1 1
// ##                              CNC configuration                                       ##
If the firmware is in CNC mode, it can control a mill with M3/M4/M5. It works
similar to laser mode, but mill keeps enabled during G0 moves and it allows
setting rpm (only with event extension that supports this) and milling direction.
It also can add a delay to wait for spindle to run on full speed.
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_ENABLE 300
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define DEFAULT_PRINTER_MODE 0
// ################ Endstop configuration #####################
#define ENDSTOP_PULLUP_X_MAX true
#define ENDSTOP_PULLUP_X_MIN true
#define ENDSTOP_PULLUP_Y_MAX true
#define ENDSTOP_PULLUP_Y_MIN true
#define ENDSTOP_PULLUP_Z_MAX true
#define ENDSTOP_PULLUP_Z_MIN true
#define ENDSTOP_X_MAX_INVERTING false
#define ENDSTOP_X_MIN_INVERTING true
#define ENDSTOP_Y_MAX_INVERTING false
#define ENDSTOP_Y_MIN_INVERTING true
#define ENDSTOP_Z_MAX_INVERTING false
#define ENDSTOP_Z_MIN_INVERTING true
#define MAX_HARDWARE_ENDSTOP_X true
#define MAX_HARDWARE_ENDSTOP_Y true
#define MAX_HARDWARE_ENDSTOP_Z true
#define MIN_HARDWARE_ENDSTOP_X false
#define MIN_HARDWARE_ENDSTOP_Y false
#define MIN_HARDWARE_ENDSTOP_Z false
#define max_software_endstop_r true
#define max_software_endstop_x true
#define max_software_endstop_y true
#define max_software_endstop_z true
#define min_software_endstop_x false
#define min_software_endstop_y false
#define min_software_endstop_z false
#define ENDSTOP_X_BACK_MOVE 10
#define ENDSTOP_Y_BACK_MOVE 10
#define ENDSTOP_Z_BACK_MOVE 10
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 4
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 4
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 4
#define ENDSTOP_X_BACK_ON_HOME 5
#define ENDSTOP_Y_BACK_ON_HOME 5
#define ENDSTOP_Z_BACK_ON_HOME 5
#define ALWAYS_CHECK_ENDSTOPS true
// ################# XYZ movements ###################
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR true
#define INVERT_Y_DIR false
#define INVERT_Z_DIR true
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 250
#define Y_MAX_LENGTH 250
#define Z_MAX_LENGTH 400
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_CORRECTION 0
#define DISTORTION_CORRECTION_POINTS 5
#define DISTORTION_CORRECTION_R 100
#define DISTORTION_PERMANENT 1
#define DISTORTION_UPDATE_FREQUENCY 15
#define DISTORTION_START_DEGRADE 0.5
#define DISTORTION_END_HEIGHT 1
#define DISTORTION_EXTRAPOLATE_CORNERS 0
// ##                           Movement settings                                          ##
#define FEATURE_BABYSTEPPING 1
#define BABYSTEP_MULTIPLICATOR 1
#define DELTA_SEGMENTS_PER_SECOND_PRINT 100 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 20 // Less accurate setting for other moves
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 269 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_RADIUS_CORRECTION_A 0
#define DELTA_RADIUS_CORRECTION_B 0
#define DELTA_RADIUS_CORRECTION_C 0
#define DELTA_DIAGONAL_CORRECTION_A 0
#define DELTA_DIAGONAL_CORRECTION_B 0
#define DELTA_DIAGONAL_CORRECTION_C 0
#define END_EFFECTOR_HORIZONTAL_OFFSET 33.0
#define CARRIAGE_HORIZONTAL_OFFSET 38.4
#define DELTA_MAX_RADIUS 135
#define ROD_RADIUS 126.85
#define PRINTER_RADIUS 198.25
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_X_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Y_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Z_ENDSTOP_OFFSET_STEPS 0
#define DELTA_FLOOR_SAFETY_MARGIN_MM 15
//#define SOFTWARE_LEVELING
#define DELTASEGMENTS_PER_PRINTLINE 22
#define STEPPER_INACTIVE_TIME 0L
#define MAX_INACTIVE_TIME 1800L
#define MAX_FEEDRATE_X 300
#define MAX_FEEDRATE_Y 300
#define MAX_FEEDRATE_Z 300
#define HOMING_FEEDRATE_X 120
#define HOMING_FEEDRATE_Y 120
#define HOMING_FEEDRATE_Z 120
#define HOMING_ORDER HOME_ORDER_ZXY
#define ZHOME_MIN_TEMPERATURE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 0
#define ZHOME_Y_POS 0
#define ENABLE_BACKLASH_COMPENSATION 0
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define STEP_DOUBLER_FREQUENCY 12000
#define ALLOW_QUADSTEPPING true
#define DOUBLE_STEP_DELAY 1 // time in microseconds
#define MAX_HALFSTEP_INTERVAL 2000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 1850
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1850
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1850
#define INTERPOLATE_ACCELERATION_WITH_Z 0
#define ACCELERATION_FACTOR_TOP 100
#define MAX_JERK 0
#define MAX_ZJERK 0
#define PRINTLINE_CACHE_SIZE 16
#define MOVE_CACHE_LOW 10
#define LOW_TICKS_PER_MOVE 250000
#define FEATURE_TWO_XSTEPPER 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define X2_ENABLE_PIN E1_ENABLE_PIN
#define FEATURE_TWO_YSTEPPER 0
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_ENABLE_PIN E1_ENABLE_PIN
#define FEATURE_TWO_ZSTEPPER 0
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_ENABLE_PIN E1_ENABLE_PIN
#define FEATURE_THREE_ZSTEPPER 0
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define Z3_ENABLE_PIN E2_ENABLE_PIN
#define FEATURE_DITTO_PRINTING 0
#define USE_ADVANCE 0
#define ENABLE_QUADRATIC_ADVANCE 0
// ################# Misc. settings ##################
#define BAUDRATE 250000
#define ENABLE_POWER_ON_STARTUP 1
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define WAITING_IDENTIFIER "wait"
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#define PS_ON_PIN ORIG_PS_ON_PIN
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
Servos are controlled by a pulse width normally between 500 and 2500 with 1500ms in center position. 0 turns servo off.
WARNING: Servos can draw a considerable amount of current. Make sure your system can handle this or you may risk your hardware!
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN 6
#define SERVO2_PIN 5
#define SERVO3_PIN 4
#define SERVO0_NEUTRAL_POS  0
#define SERVO1_NEUTRAL_POS  0
#define SERVO2_NEUTRAL_POS  0
#define SERVO3_NEUTRAL_POS  0
#define UI_SERVO_CONTROL 0
#define FAN_KICKSTART_TIME  200
#define FEATURE_WATCHDOG 1
// #################### Z-Probing #####################
#define Z_PROBE_Z_OFFSET 0
#define Z_PROBE_Z_OFFSET_MODE 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 10
#define Z_PROBE_PIN 63
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_WAIT_BEFORE_TEST 1
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 1
#define Z_PROBE_REPETITIONS 5
#define Z_PROBE_HEIGHT 39.91
#define Z_PROBE_START_SCRIPT ""
#define Z_PROBE_FINISHED_SCRIPT ""
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 100
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 170
#define Z_PROBE_X3 20
#define Z_PROBE_Y3 170
#define BENDING_CORRECTION_A 0
#define BENDING_CORRECTION_B 0
#define BENDING_CORRECTION_C 0
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
#define SDSUPPORT 1
#define SDCARDDETECT 81
#define SDCARDDETECTINVERTED 0
#endif
#define SD_EXTENDED_DIR 1 /** Show extended directory including file length. Don't use this with Pronterface! */
#define SD_RUN_ON_STOP ""
#define SD_STOP_HEATER_AND_MOTORS_ON_STOP 1
#define ARC_SUPPORT 0
#define FEATURE_MEMORY_POSITION 1
#define FEATURE_CHECKSUM_FORCED 0
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 13
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define UI_PRINTER_NAME "Rostock MAX V2"
#define UI_PRINTER_COMPANY "SeeMeCNC"
#define UI_PAGES_DURATION 4000
#define UI_ANIMATION 0
#define UI_SPEEDDEPENDENT_POSITIONING 1
#define UI_DISABLE_AUTO_PAGESWITCH 1
#define UI_AUTORETURN_TO_MENU_AFTER 60000
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_FIRST_REPEAT 500
#define UI_KEY_REDUCE_REPEAT 50
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define CASE_LIGHT_DEFAULT_ON 1
#define UI_START_SCREEN_DELAY 1000
#define UI_DYNAMIC_ENCODER_SPEED 1
Beeper sound definitions for short beeps during key actions
and longer beeps for important actions.
Parameter is delay in microseconds and the secons is the number of repetitions.
Values must be in range 1..255
#define BEEPER_SHORT_SEQUENCE 1,1
#define BEEPER_LONG_SEQUENCE 32,4
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 60
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   180
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 80
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   225
#define UI_SET_MIN_HEATED_BED_TEMP  40
#define UI_SET_MAX_HEATED_BED_TEMP 100
#define UI_SET_MIN_EXTRUDER_TEMP   150
#define UI_SET_MAX_EXTRUDER_TEMP   240
#define UI_SET_EXTRUDER_FEEDRATE 2
#define UI_SET_EXTRUDER_RETRACT_DISTANCE 3
#define NUM_MOTOR_DRIVERS 0
#endif
TIA!!!
-Bishop
Re: Weird Stepper Motor Behavior
Posted: Wed Nov 18, 2015 12:07 pm
Heat the printer up (bed & hot end) and stick a volt meter on the power leads feeding the RAMBo. I'm betting you've got a power supply problem on your hands.
Posted: Wed Nov 18, 2015 12:40 pm
by Bishop
geneb wrote:Heat the printer up (bed & hot end) and stick a volt meter on the power leads feeding the RAMBo. I'm betting you've got a power supply problem on your hands.
I was thinking that could be part of the problem, but when running 0.91 everything works as expected. Maybe the P/S was right on the edge and the 0.92 version of firmware uses just enough 'extra' power (PWM timing etc) to push it over the edge. I'll try that out this week and let you know what I find.
Thanks for the quick response!!!
Posted: Thu Nov 19, 2015 12:09 pm
by Bishop
I got a chance to check the voltages and here's what I found.
Steppers Engaged with Heaters OFF: 12.05VDC +-0.01VDC
Steppers Engaged with Heaters ON: 11.05VDC +-0.01VDC
After the weird stepper motor behavior ('hiccups') started, the voltages jumped around from 10.52VDC to 11.47VDC; but only when using the 0.92 firmware. I never saw this behavior on the 0.91 firmware version.
So that makes me wonder if the voltage jumping around is a cause or a symptom. Could the onset of this issue corresponding with the timing of my firmware upgrade just be a coincidence?
Any thoughts?
Posted: Thu Nov 19, 2015 12:13 pm
At 11v, the power supply isn't doing it's job. The voltage shouldn't sag like that under load.
Posted: Wed Nov 25, 2015 11:23 am
by Bishop
Okay...so I finally got this figured out.
Even though my printer was working with version 0.91, I went ahead and swapped out the power supply to rule this out as the cause. New power supply did not have any effect, so I started looking more into the code. What I found was version 0.91 did not actually use current percentages like the const MOTOR_CURRENT_PERCENT would have you believe.
RAMBo boards use digipots (digital potentiometers) to control the current and have a range from 0-255 (0 being the off and 255 being the max; which is 2.0A for my version).
Version 0.92 implemented a method (void setMotorCurrentPercent( uint8_t channel, float level)) to use MOTOR_CURRENT_PERCENT and actually treat it as a percentage. setMotorCurrentPercent calculated the percentage of max current ( level * 255 / 100 ) before setting the current level. So my problem was trying to set the percentage to over 100% (based on the settings from version 0.91) which was causing the stepper motor controllers to overheat causing a thermal brake to kick in to protect the ICs. When the thermal brake is active, the stepper motor controllers ignore move commands.
Given this finding, it was easy to calculate the actual percentage and adjust the Configuration.h file accordingly.
#if USE_LOW_CURRENT // Kysan steppers require a lower current than the Wantai steppers
#define MOTOR_CURRENT_PERCENT { 55, 55, 55, 63, 0 } // 140 / 255 = 55% and 160 / 255  = 63%
#else
#define MOTOR_CURRENT_PERCENT { 68, 68, 68, 78, 0 } // 175 / 255 = 68% and 200 / 255 = 78%
#endif
I have been printing with these settings for two days and everything is working well.
Not sure if this will help anyone else, but I wanted to share just in case.
-Bishop
Posted: Wed Nov 25, 2015 1:53 pm
by Eric
So either the drivers or the motors were overheating and misbehaving. The bed/extruder heat symptom was a goose chase, as it was really a function of power-on time.
It was previously called MOTOR_CURRENT{}, so I guess having _PERCENT added is your clue.
Still, it could be quite a gotcha when the next stable version is released...one more thing for geneb to cover it in the manual.
Posted: Wed Nov 25, 2015 3:28 pm
by Bishop
Yea...having the bed and hot end turned on may not have even been a factor.
One good thing has come from all of this...aside from having my printer working again. While digging through the firmware code, I gained a better understanding of the actual print process and have a better idea of how to fine tune things!
Maybe I should break my printer more often!
Posted: Wed Nov 25, 2015 3:57 pm
I would add a larger fan to blow onto the Rambo card, install a better power supply.
