Can no longer print at all SOLVED PS was at 220v not 115v
Posted: Mon Dec 28, 2015 11:54 pm
by Windshadow
after I attempted to print
the part from this page 110 of the manual after I got a useable PPK fan holder printed (seen on page 2 of my build thread) after i adjusted the end stop on the Gamma tower and switched to using paper .07mm thick from .12mm thick
the tower homed after I hit print (after I used my heat gun to careful raise the bed temp to 80 so printing would start. which was what i had to do to do the peek fan housing to start.)
this is the print I was attempting as referenced here at page 110 the manual
http://www.thingiverse.com/thing:50505\n
Highcooley's Onyx Bed Leveling Aid is a great one to test your calibration. Highly recommended. If you can print it perfectly you've "arrived".
then it dived to a spot just between the Alpha tower and the gamma tower about 5 inches above the bed and made stuttering sounds before I turned off the printer
so I went to the simple circles 6mm high from page 110
http://forum.seemecnc.com/download/file.php?id=8210
and did a tower cal and a reset z hight and tried to print... this time it went to a spot about 4 or 5 inch above the bed again near the Alpha tower and started to air print
so i shut down the printer and restarted it and rebooted the macbook pro I am using to drive the mater control i redid the clear memory and reinstall from page 10 and 12 the “Repetier.ino”
and redid tower cal and set for the z hight and tried the 6mm circle again and once again it went to AirPrint in the same area near the alpha tower
after it all being shut down over night I am trying to heat the bed again and once again when 80c is commanded the max it gets to is 73 then it drops to 67 and inches back to 72 or 73 and swings between the two.... i again heated the bed with the heat gun to 80c so it could start the print
the effector homed and once again started to air print the 6mm high small circle near the alpha tower even this on the MC screen it is properly seen as centered on the build plate.
Have I some how mangled the EEPROM settings? the only thing that is going to the center and a paper thickness of the bed is the tower cal macro any thing I attempt to print if it is small like those test circles air prints near the Alpha (X) tower if it is large like the bed leveling aid it also air prints but attempts to get outside the build area with much buzzing...
the important thing is that the first print all was ok except for bed adhesion caused by the bed that cooled to 72c during the course of the print
and I a got a usable fan shroud on the 3rd try
All of this started when I attempted to print the
Re: Can no longer print at all
Posted: Tue Dec 29, 2015 12:10 am
by Earthbound
If your printer goes to the correct positions when the tower calibration macros are run, then your EEPROM settings are likely fine. So if everything you try to print goes to the wrong spot, then the problem is likely in your slicer settings. Could be bed dimensions, bed center, maximum height, gcode format, or all of the above.
I can't tell you what the correct settings will be. I stopped using Matter Control.
Posted: Tue Dec 29, 2015 12:57 am
by Windshadow
Thanks I have never yet looked at the slicer I just downloaded the files added them to MC and set z and hit print... In the morning I will see if they are the culprit
Posted: Tue Dec 29, 2015 1:18 am
by Earthbound
Some of the settings may look a little odd, since they may be framed in the assumption of Cartesian movement printers. Matter Control may show the round bed and center the model in the view, but somewhere the slicer needs to be told the bed size and center point. This handshaking of information gets a little broken sometimes when one bit of software gets updated but the other components haven't gotten the same translation.
I encourage you to explore other software options. I got my Max when Repetier-Host was the norm and Matter Control was still getting traction. I moved to MC early. Then there were a series of updates that broke more than they fixed, in my opinion. I no longer print while connected to the PC, so my go to slicer is now KISSlicer.
Posted: Tue Dec 29, 2015 2:00 pm
by Windshadow
well aside from the fact that even setting the bed heater control to 3 (it now won't heat above 64c)
the hot end will no longer get to 228 it stops at 223 and i did re run the autotune for it when i installed the peek fan
it still starts anything i try to print about an inch above the build plate and an inch or so from the centre at 8 o'clock
Posted: Tue Dec 29, 2015 2:18 pm
by Windshadow
This is the G code from the last attempt and I don't know enough to interpret it
the file is the second print form the user guide for the layer fan
http://repables.com/r/621/\n
->Communication State: PreparingToPrint
->N1 M110 S1*96
<-ok
<-wait
->M105
<-ok 1
<-T:228.57 B:82.33 B@:0 @:255
<-wait
<-wait
->M105
<-ok 1
<-T:228.86 B:82.43 B@:0 @:201
<-wait
<-wait
->M105
<-ok 1
<-T:229.14 B:82.62 B@:0 @:198
<-wait
<-wait
->M105
<-ok 1
<-T:229.71 B:82.84 B@:0 @:255
<-wait
<-wait
->M105
<-ok 1
<-T:229.71 B:83.12 B@:0 @:255
<-wait
<-wait
->M105
<-ok 1
<-T:230.34 B:83.34 B@:0 @:255
<-wait
<-wait
->M105
<-ok 1
<-T:231.03 B:83.56 B@:0 @:255
<-wait
<-wait
->M105
<-ok 1
<-T:231.03 B:83.72 B@:0 @:255
<-wait
<-wait
->M105
<-ok 1
<-T:231.03 B:83.85 B@:0 @:255
<-wait
<-wait
->M105
<-ok 1
<-T:231.72 B:83.85 B@:0 @:255
<-wait
<-wait
->M105
<-ok 1
<-T:232.07 B:83.94 B@:0 @:242
->Communication State: Printing
->N2 G21*24 [0.075]
<-ok 2 [0.081]
<- [0.081]
->N3 M107*38 [0.084]
<-ok 3 [0.088]
<- [0.088]
->N4 T0*62 [0.090]
<-ok 4 [0.103]
<- [0.103]
->N5 M104 S228*104 [0.107]
<-ok 5 [0.112]
<- [0.112]
<-TargetExtr0:228 [0.112]
<- [0.112]
->N6 M104 T0 S228*47 [0.113]
<-ok 6 [0.116]
<- [0.116]
->N7 M190 S80*87 [0.117]
<-TargetExtr0:228 [0.123]
<- [0.123]
<-ok 7 [0.123]
<- [0.123]
->N8 M109 S228*104 [0.124]
<-ok 8 [0.153]
<- [0.153]
->N9 G28*26 [0.154]
<-TargetExtr0:228 [0.198]
<- [0.198]
<-T:232.07 B:83.97 B@:0 @:151 [1.189]
<- [1.251]
<-T:232.07 B:83.97 B@:0 @:149 [2.189]
<- [2.202]
<-T:232.07 B:83.97 B@:0 @:245 [3.193]
<- [3.303]
<-T:232.41 B:83.97 B@:0 @:141 [4.192]
<- [4.254]
<-T:232.41 B:83.94 B@:0 @:139 [5.192]
<- [5.226]
<-T:232.07 B:83.88 B@:0 @:239 [6.195]
<- [6.196]
<-T:232.41 B:83.85 B@:0 @:37 [7.194]
<- [7.326]
<-T:232.41 B:83.85 B@:0 @:0 [8.194]
<- [8.297]
<-T:232.07 B:83.85 B@:0 @:135 [9.198]
<- [9.227]
<-T:232.41 B:83.75 B@:0 @:129 [10.197]
<- [10.632]
<-T:232.41 B:83.72 B@:0 @:127 [11.201]
<- [11.283]
<-T:232.41 B:83.72 B@:0 @:125 [12.201]
<- [12.266]
<-T:232.41 B:83.60 B@:0 @:123 [13.200]
<- [13.213]
<-T:232.07 B:83.60 B@:0 @:223 [14.203]
<- [14.337]
<-T:232.41 B:83.50 B@:255 @:21 [15.203]
<- [15.287]
<-T:231.38 B:83.47 B@:0 @:130 [16.206]
<- [16.241]
<-T:231.03 B:83.38 B@:255 @:133 [17.210]
<- [17.212]
<-T:231.03 B:83.34 B@:0 @:131 [18.209]
<- [18.344]
<-T:231.38 B:83.28 B@:255 @:28 [19.209]
<- [19.317]
<-T:231.03 B:83.22 B@:0 @:128 [20.212]
<- [20.268]
<-T:231.03 B:83.15 B@:0 @:127 [21.213]
<- [21.221]
<-T:231.03 B:83.09 B@:0 @:126 [22.211]
<- [22.320]
<-T:230.34 B:82.97 B@:255 @:255 [23.215]
<- [23.305]
<-T:230.00 B:82.97 B@:0 @:234 [24.214]
<- [24.282]
<-T:229.71 B:82.84 B@:0 @:255 [25.214]
<- [25.257]
<-T:230.00 B:82.78 B@:255 @:53 [26.217]
<- [26.231]
<-T:229.71 B:82.71 B@:0 @:137 [27.218]
<- [27.366]
<-T:229.71 B:82.62 B@:255 @:136 [28.220]
<- [28.340]
<-T:229.43 B:82.52 B@:0 @:139 [29.220]
<- [29.295]
<-T:229.43 B:82.46 B@:0 @:220 [30.219]
<- [30.269]
<-T:228.57 B:82.37 B@:255 @:149 [31.224]
<- [31.372]
<-ok 9 [32.059]
<- [32.207]
->N10 M114*22 [32.208]
<-ok 10 [32.214]
<- [32.214]
<-X:0.00 Y:0.00 Z:373.56 E:10.00 [32.911]
<- [33.030]
->N11 M105*23 [33.031]
<-ok 11 [33.034]
<- [33.034]
->N12 M105*20 [33.035]
<-T:228.86 B:82.24 B@:255 @:64 [33.039]
<- [33.039]
<-ok 12 [33.039]
<- [33.039]
->N13 T0*8 [33.041]
<-T:228.86 B:82.24 B@:255 @:64 [33.043]
<- [33.043]
<-ok 13 [33.046]
<- [33.046]
->N14 G90*37 [33.048]
<-ok 14 [33.054]
<- [33.054]
->N15 G92 E0*115 [33.055]
<-ok 15 [33.058]
<- [33.058]
->N16 M82*46 [33.059]
<-ok 16 [33.062]
<- [33.062]
->N17 M107*19 [33.066]
<-ok 17 [33.070]
<- [33.070]
->N18 G0 F18000 X10.249 Y-8.51 Z0.3*54 [33.071]
<-ok 18 [33.078]
<- [33.078]
->N19 G1 Z0.3*71 [33.080]
<-ok 19 [33.111]
<- [33.248]
->N20 G1 F6600 E0*41 [33.249]
<-ok 20 [33.255]
<- [33.255]
->N21 G1 F720 X11.241 Y-8.244 E0.05182*28 [33.257]
<-ok 21 [33.267]
<- [33.267]
->N22 G1 X12.206 Y-7.794 E0.10553*71 [33.268]
<-ok 22 [33.291]
<- [33.291]
->N23 G1 X13.08 Y-7.182 E0.15935*115 [33.292]
<-ok 23 [33.320]
<- [33.471]
->N24 G1 X13.833 Y-6.429 E0.21305*79 [33.472]
<-ok 24 [33.481]
<- [33.481]
->N25 G1 X14.445 Y-5.555 E0.26685*71 [33.482]
<-ok 25 [33.504]
<- [33.650]
->N26 G1 X14.895 Y-4.59 E0.32054*114 [33.651]
<-ok 26 [33.668]
<- [33.668]
->N27 G1 X15.171 Y-3.561 E0.37426*76 [33.669]
<-ok 27 [33.717]
<- [33.853]
->N28 G1 X15.25 Y-2.656 E0.42005*114 [33.855]
<-ok 28 [33.865]
<- [33.865]
->N29 G1 X15.25 Y2.657 E0.68812*89 [33.866]
<-ok 29 [33.910]
<- [33.910]
->N30 G1 X15.171 Y3.562 E0.73397*105 [33.911]
<-ok 30 [34.021]
<- [34.090]
->N31 G1 X14.895 Y4.591 E0.78773*100 [34.091]
<-Error:Wrong checksum [34.099]
<- [34.099]
<- [34.099]
<- [34.099]
<-Resend:31 [34.103]
<- [34.103]
<-ok [34.103]
<- [34.103]
->N31 G1 X14.895 Y4.591 E0.78773*10 [34.104]
<-ok 31 [34.123]
<- [34.271]
->N32 G1 X14.445 Y5.556 E0.84147*110 [34.273]
<-ok 32 [34.283]
<- [34.283]
->N33 G1 X13.833 Y6.43 E0.89531*95 [34.284]
<-Error:Wrong checksum [34.488]
<- [34.605]
<- [34.605]
<- [34.605]
<-Resend:33 [34.605]
<- [34.605]
<-ok [34.605]
<- [34.605]
->N33 G1 X13.833 Y6.43 E0.89531*9 [34.606]
<-ok 33 [34.616]
<- [34.616]
->N34 G1 X13.08 Y7.183 E0.94905*83 [34.617]
<-ok 34 [34.661]
<- [34.786]
->N35 G1 X12.206 Y7.795 E1.0029*85 [34.787]
<-ok 35 [34.795]
<- [34.795]
->N36 G1 X11.241 Y8.245 E1.05663*108 [34.796]
<-ok 36 [34.833]
<- [34.968]
->N37 G1 X10.25 Y8.511 E1.10841*80 [34.969]
<-ok 37 [34.975]
<- [34.975]
->N38 G1 X10.25 Y16.462 E1.50966*101 [34.977]
<-ok 38 [35.012]
<- [35.012]
->N39 G1 X10.056 Y17.567 E1.56628*86 [35.014]
<-ok 39 [35.102]
<- [35.197]
->N40 G1 X9.332 Y18.824 E1.63948*107 [35.198]
<-ok 40 [35.708]
<- [35.833]
->N41 M105*18 [35.834]
<-ok 41 [35.839]
<- [35.839]
->N42 G1 X8.228 Y19.745 E1.71204*107 [35.840]
<-ok 42 [35.962]
<- [36.014]
<-T:227.43 B:81.99 B@:255 @:163 [36.014]
<- [36.014]
->N43 G1 X6.88 Y20.242 E1.78454*94 [36.015]
<-ok 43 [36.020]
<- [36.020]
->N44 G1 X-6.46 Y20.249 E2.45775*112 [36.021]
<-ok 44 [36.139]
<- [36.249]
->N45 G1 X-7.572 Y20.054 E2.51477*72 [36.251]
<-ok 45 [36.319]
<- [36.430]
->N46 G1 X-8.818 Y19.331 E2.58752*66 [36.432]
<-ok 46 [37.371]
<- [37.388]
->N47 G1 X-9.748 Y18.227 E2.66039*72 [37.389]
<-ok 47 [37.433]
<- [37.569]
->N48 M105*27 [37.571]
<-ok 48 [37.577]
<- [37.577]
->N49 G1 X-10.239 Y16.869 E2.73329*117 [37.578]
<-ok 49 [37.703]
<- [37.751]
<-T:226.57 B:81.86 B@:255 @:255 [37.751]
<- [37.752]
->N50 G1 X-10.247 Y8.511 E3.15507*66 [37.753]
<-ok 50 [37.760]
<- [37.760]
->N51 G1 X-11.239 Y8.245 E3.20695*67 [37.761]
<-ok 51 [37.887]
<- [37.955]
->N52 G1 X-12.204 Y7.795 E3.26073*66 [37.956]
<-ok 52 [38.634]
<- [38.697]
->N53 G1 X-13.078 Y7.183 E3.31462*72 [38.698]
<-ok 53 [38.723]
<- [38.723]
->N54 G1 X-13.831 Y6.43 E3.3684*77 [38.724]
<-ok 54 [38.817]
<- [38.905]
->N55 G1 X-14.443 Y5.556 E3.42227*72 [38.906]
<-ok 55 [38.911]
<- [38.911]
->N56 G1 X-14.893 Y4.591 E3.47602*70 [38.912]
<-ok 56 [38.940]
<- [39.087]
->N57 G1 X-15.169 Y3.562 E3.5298*112 [39.089]
<-ok 57 [39.096]
<- [39.096]
->N58 M105*26 [39.097]
<-ok 58 [39.100]
<- [39.100]
->N59 G1 X-15.248 Y2.657 E3.57565*72 [39.101]
<-ok 59 [39.121]
<- [39.270]
<-T:226.29 B:81.80 B@:0 @:179 [39.270]
<- [39.271]
->N60 G1 X-15.248 Y-2.656 E3.84377*101 [39.272]
<-ok 60 [39.276]
<- [39.276]
->N61 G1 X-15.169 Y-3.561 E3.88966*100 [39.277]
<-ok 61 [39.284]
<- [39.284]
->N62 G1 X-14.893 Y-4.59 E3.94346*86 [39.285]
<-ok 62 [39.616]
<- [39.647]
->N63 G1 X-14.443 Y-5.555 E3.99722*101 [39.648]
<-ok 63 [39.703]
<- [39.829]
->N64 G1 X-13.831 Y-6.429 E4.05108*105 [39.831]
<-ok 64 [39.837]
<- [39.837]
->N65 G1 X-13.078 Y-7.182 E4.10482*107 [39.838]
<-ok 65 [39.878]
<- [40.012]
->N66 G1 X-12.204 Y-7.794 E4.15865*97 [40.014]
<-ok 66 [40.017]
<- [40.017]
->N67 G1 X-11.239 Y-8.244 E4.21236*97 [40.018]
<-ok 67 [40.050]
<- [40.195]
->N68 G1 X-10.247 Y-8.51 E4.26416*83 [40.197]
<-ok 68 [40.203]
<- [40.203]
->N69 G1 X-10.24 Y-20.249 E4.85662*108 [40.204]
<-ok 69 [40.226]
<- [40.377]
->N70 G1 X10.236 Y-20.249 E5.8899*70 [40.378]
<-ok 70 [40.382]
->N71 G1 X10.249 Y-8.51 E6.48226*119 [40.383]
<- [40.386]
<-ok 71 [41.181]
<- [41.186]
->N72 G0 F18000 X10.137 Y-8.126*86 [41.188]
<-ok 72 [42.877]
<- [43.082]
->N73 M105*19 [43.084]
<-ok 73 [43.828]
<- [43.891]
->N74 G1 F720 X11.104 Y-7.866 E6.53278*24 [43.893]
<-ok 74 [43.917]
<- [43.917]
<-T:226.00 B:81.45 B@:0 @:0 [43.917]
<- [43.918]
->N75 G1 X12.006 Y-7.446 E6.58297*78 [43.919]
<-ok 75 [43.925]
<- [43.925]
->N76 G1 X12.822 Y-6.875 E6.6332*123 [43.926]
<-ok 76 [44.016]
<- [44.124]
->N77 G1 X13.526 Y-6.171 E6.68341*67 [44.125]
<-ok 77 [44.130]
<- [44.130]
->N78 G1 X14.097 Y-5.355 E6.73363*73 [44.131]
<-ok 78 [44.208]
<- [44.306]
->N79 G1 X14.517 Y-4.453 E6.78379*69 [44.307]
<-ok 79 [44.314]
<- [44.314]
->N80 G1 X14.775 Y-3.492 E6.83396*74 [44.315]
<-ok 80 [44.396]
<- [44.488]
->N81 G1 X14.85 Y-2.639 E6.87712*125 [44.490]
<-ok 81 [44.495]
<- [44.495]
->N82 G1 X14.85 Y2.64 E7.14348*109 [44.496]
<-ok 82 [44.593]
<- [44.671]
->N83 G1 X14.775 Y3.493 E7.18669*99 [44.673]
<-ok 83 [44.691]
<- [44.691]
->N84 G1 X14.517 Y4.454 E7.23691*97 [44.692]
<-ok 84 [45.180]
<- [45.205]
->N85 G1 X14.097 Y5.356 E7.28712*104 [45.206]
<-ok 85 [45.277]
<- [45.388]
->N86 G1 X13.526 Y6.172 E7.33738*102 [45.389]
<-ok 86 [45.397]
<- [45.397]
->N87 M105*24 [45.398]
<-ok 87 [45.404]
<- [45.404]
->N88 G1 X12.822 Y6.876 E7.38762*105 [45.405]
<-ok 88 [45.474]
<- [45.598]
<-T:225.43 B:81.32 B@:255 @:196 [45.598]
<- [45.598]
->N89 G1 X12.006 Y7.447 E7.43788*97 [45.599]
<-ok 89 [45.605]
<- [45.605]
->N90 G1 X11.104 Y7.867 E7.4881*82 [45.606]
<-ok 90 [45.614]
<- [45.614]
->N91 G1 X10.145 Y8.125 E7.53821*111 [45.615]
<-ok 91 [45.639]
<- [45.639]
->N92 G1 X9.85 Y8.151 E7.55316*99 [45.640]
<-ok 92 [45.725]
<- [45.828]
->N93 G1 X9.85 Y16.428 E7.97086*82 [45.830]
<-ok 93 [45.867]
<- [45.867]
->N94 G1 X9.674 Y17.429 E8.02215*102 [45.868]
<-ok 94 [45.883]
<- [45.883]
->N95 G1 X9.021 Y18.562 E8.08814*97 [45.884]
<-ok 95 [46.555]
<- [46.663]
->N96 G1 X8.025 Y19.394 E8.15364*105 [46.665]
<-ok 96 [46.671]
<- [46.671]
->N97 G1 X6.808 Y19.842 E8.21908*102 [46.672]
<-ok 97 [46.802]
<- [46.845]
->N98 G1 X-6.426 Y19.849 E8.88694*70 [46.846]
<-ok 98 [46.969]
<- [47.048]
->N99 G1 X-7.432 Y19.673 E8.93853*75 [47.049]
<-ok 99 [47.134]
<- [47.230]
->N100 G1 X-8.557 Y19.02 E9.00422*70 [47.232]
<-ok 100 [48.046]
<- [48.193]
->N101 G1 X-9.396 Y18.024 E9.06997*125 [48.194]
<-ok 101 [48.202]
<- [48.202]
->N102 M105*36 [48.203]
<-ok 102 [48.206]
<- [48.206]
->N103 G1 X-9.839 Y16.799 E9.13572*125 [48.208]
<-ok 103 [48.354]
<- [48.375]
<-T:224.29 B:81.14 B@:255 @:214 [48.375]
<- [48.376]
->N104 G1 X-9.847 Y8.151 E9.57215*72 [48.377]
<-ok 104 [48.382]
<- [48.382]
->N105 G1 X-10.141 Y8.125 E9.58709*122 [48.383]
<-ok 105 [48.538]
<- [48.579]
->N106 G1 X-11.102 Y7.867 E9.63736*123 [48.581]
<-ok 106 [49.276]
<- [49.385]
->N107 G1 X-12.004 Y7.447 E9.68762*122 [49.386]
<-ok 107 [49.395]
<- [49.395]
->N108 G1 X-12.82 Y6.876 E9.73792*65 [49.396]
<-ok 108 [49.452]
<- [49.567]
->N109 G1 X-13.524 Y6.172 E9.7882*72 [49.569]
<-ok 109 [49.575]
<- [49.575]
->N110 G1 X-14.095 Y5.356 E9.83849*116 [49.576]
<-ok 110 [49.582]
<- [49.582]
->N111 G1 X-14.515 Y4.454 E9.88872*127 [49.583]
<-ok 111 [49.615]
<- [49.750]
->N112 G1 X-14.773 Y3.493 E9.93895*113 [49.752]
<-ok 112 [49.758]
<- [49.758]
->N113 M105*36 [49.759]
<-ok 113 [49.762]
<- [49.762]
->N114 G1 X-14.848 Y2.64 E9.98216*71 [49.764]
<-ok 114 [49.779]
<- [49.779]
<-T:224.86 B:81.07 B@:255 @:209 [49.779]
<- [49.779]
->N115 G1 X-14.848 Y-2.639 E10.24857*101 [49.780]
<-ok 115 [49.789]
<- [49.789]
->N116 G1 X-14.773 Y-3.492 E10.29183*110 [49.790]
<-ok 116 [49.870]
<- [50.133]
->N117 G1 X-14.515 Y-4.453 E10.34208*107 [50.134]
<-ok 117 [50.320]
<- [50.336]
->N118 G1 X-14.095 Y-5.355 E10.39232*109 [50.338]
<-ok 118 [50.410]
<- [50.529]
->N119 G1 X-13.524 Y-6.171 E10.44259*100 [50.530]
<-ok 119 [50.537]
<- [50.537]
->N120 G1 X-12.82 Y-6.875 E10.49283*81 [50.538]
<-ok 120 [50.545]
<- [50.546]
->N121 G1 X-12.004 Y-7.446 E10.54308*109 [50.547]
<-ok 121 [50.606]
<- [50.890]
->N122 G1 X-11.102 Y-7.866 E10.59327*100 [50.891]
<-ok 122 [50.897]
<- [50.897]
->N123 G1 X-10.134 Y-8.126 E10.64382*98 [50.898]
<-ok 123 [50.905]
<- [50.905]
->N124 G1 X-9.848 Y-8.15 E10.65825*105 [50.906]
<-ok 124 [50.913]
<- [50.913]
->N125 G1 X-9.84 Y-19.849 E11.2487*101 [50.914]
<-ok 125 [50.938]
<- [50.938]
->N126 G1 X9.836 Y-19.849 E12.2416*113 [50.939]
<-ok 126 [51.021]
<- [51.128]
->N127 G1 X9.849 Y-8.15 E12.83195*78 [51.129]
<-ok 127 [51.864]
<- [51.864]
->N128 G1 X10.137 Y-8.126 E12.84653*66 [51.866]
<-ok 128 [53.367]
<- [53.367]
->N129 M105*45 [53.368]
<-ok 129 [54.335]
<- [54.460]
<-T:222.86 B:80.82 B@:0 @:255 [54.460]
<- [54.461]
->N130 G0 F18000 X9.549 Y-4.764*88 [54.462]
<-ok 130 [54.469]
<- [54.469]
->N131 G1 F720 X9.938 Y-4.659 E12.86685*44 [54.471]
<-ok 131 [54.477]
<- [54.477]
->N132 G1 X10.296 Y-4.492 E12.88676*76 [54.479]
<-ok 132 [54.522]
<- [54.522]
->N133 G1 X10.632 Y-4.257 E12.90742*71 [54.523]
<-ok 133 [54.621]
<- [54.695]
->N134 G1 X10.908 Y-3.981 E12.92709*76 [54.696]
<-ok 134 [54.715]
<- [54.715]
->N135 G1 X11.143 Y-3.645 E12.94774*64 [54.716]
<-ok 135 [54.813]
<- [54.906]
->N136 G1 X11.31 Y-3.287 E12.96763*121 [54.907]
<-ok 136 [54.911]
<- [54.911]
->N137 G1 X11.415 Y-2.897 E12.98796*68 [54.912]
<-ok 137 [55.006]
<- [55.101]
->N138 G1 X11.45 Y-2.499 E13.00807*127 [55.102]
<-ok 138 [55.108]
<- [55.109]
->N139 G1 X11.45 Y2.5 E13.2603*106 [55.110]
<-ok 139 [55.203]
<- [55.285]
->N140 G1 X11.415 Y2.898 E13.28046*102 [55.286]
<-ok 140 [55.301]
<- [55.301]
->N141 G1 X11.31 Y3.288 E13.30084*88 [55.302]
<-ok 141 [55.792]
<- [55.818]
->N142 G1 X11.143 Y3.646 E13.32078*104 [55.819]
<-ok 142 [55.886]
<- [56.001]
->N143 G1 X10.908 Y3.982 E13.34147*99 [56.003]
<-ok 143 [56.009]
<- [56.009]
->N144 M105*38 [56.010]
<-ok 144 [56.013]
<- [56.013]
->N145 G1 X10.632 Y4.258 E13.36117*111 [56.015]
<-T:223.43 B:80.69 B@:255 @:255 [56.017]
<- [56.017]
<-ok 145 [56.021]
<- [56.021]
->N146 G1 X10.296 Y4.493 E13.38186*97 [56.023]
<-ok 146 [56.030]
<- [56.030]
->N147 G1 X9.938 Y4.66 E13.4018*80 [56.031]
<-ok 147 [56.038]
<- [56.038]
->N148 G1 X9.549 Y4.765 E13.42213*90 [56.039]
<-ok 148 [56.067]
<- [56.067]
->N149 G1 X8.675 Y4.842 E13.46641*91 [56.068]
<-ok 149 [56.100]
<- [56.235]
->N150 G1 X8.221 Y4.964 E13.49013*93 [56.237]
<-ok 150 [56.243]
<- [56.243]
->N151 G1 X7.795 Y5.164 E13.51388*88 [56.244]
<-ok 151 [56.251]
<- [56.251]
->N152 G1 X7.41 Y5.434 E13.53761*100 [56.252]
<-ok 152 [56.260]
<- [56.260]
->N153 G1 X7.078 Y5.768 E13.56138*90 [56.261]
<-ok 153 [56.267]
<- [56.267]
->N154 G1 X6.81 Y6.152 E13.58501*102 [56.268]
<-ok 154 [56.316]
<- [56.446]
->N155 G1 X6.611 Y6.58 E13.60883*111 [56.447]
<-ok 155 [56.452]
<- [56.452]
->N156 G1 X6.491 Y7.027 E13.63219*85 [56.453]
<-ok 156 [56.485]
<- [56.629]
->N157 G1 X6.45 Y7.49 E13.65564*90 [56.631]
<-ok 157 [56.636]
<- [56.637]
->N158 G1 X6.45 Y16.131 E14.09171*86 [56.638]
<-ok 158 [56.648]
<- [56.648]
->N159 G1 X6.429 Y16.251 E14.09786*98 [56.650]
<-ok 159 [56.681]
<- [56.681]
->N160 G1 X6.378 Y16.339 E14.10299*103 [56.682]
<-ok 160 [56.992]
<- [57.012]
->N161 G1 X6.298 Y16.406 E14.10826*108 [57.013]
<-ok 161 [57.030]
<- [57.030]
->N162 G1 X6.201 Y16.442 E14.11348*109 [57.031]
<-ok 162 [57.066]
<- [57.066]
->N163 G1 X-6.13 Y16.449 E14.73577*117 [57.067]
<-ok 163 [57.108]
<- [57.250]
->N164 G1 X-6.25 Y16.428 E14.74197*125 [57.251]
<-ok 164 [57.259]
<- [57.259]
->N165 G1 X-6.338 Y16.377 E14.74714*67 [57.261]
<-ok 165 [57.939]
<- [58.058]
->N166 G1 X-6.405 Y16.297 E14.75244*71 [58.060]
<-ok 166 [58.066]
<- [58.066]
->N167 M105*39 [58.067]
<-ok 167 [58.070]
<- [58.070]
->N168 G1 X-6.44 Y16.201 E14.75762*118 [58.072]
<-T:223.14 B:80.60 B@:255 @:247 [58.074]
<- [58.074]
<-ok 168 [58.078]
<- [58.078]
->N169 G1 X-6.448 Y7.486 E15.19742*127 [58.079]
<-ok 169 [58.086]
<- [58.086]
->N170 G1 X-6.49 Y7.022 E15.22094*76 [58.087]
<-ok 170 [58.094]
<- [58.094]
->N171 G1 X-6.614 Y6.57 E15.2446*121 [58.096]
<-ok 171 [58.717]
<- [58.745]
->N172 G1 X-6.813 Y6.144 E15.26835*126 [58.746]
<-ok 172 [58.807]
<- [58.949]
->N173 G1 X-7.08 Y5.762 E15.2919*116 [58.951]
<-ok 173 [58.954]
<- [58.954]
->N174 G1 X-7.413 Y5.43 E15.31567*76 [58.955]
<-ok 174 [58.995]
<- [59.085]
->N175 G1 X-7.799 Y5.16 E15.33948*79 [59.086]
<-ok 175 [59.094]
<- [59.094]
->N176 G1 X-8.225 Y4.962 E15.36323*120 [59.095]
<-ok 176 [59.102]
<- [59.102]
->N177 G1 X-8.679 Y4.84 E15.38701*79 [59.103]
<-ok 177 [59.110]
<- [59.111]
->N178 G1 X-9.546 Y4.765 E15.43097*114 [59.112]
<-ok 178 [59.118]
<- [59.118]
->N179 G1 X-9.936 Y4.66 E15.45141*64 [59.119]
<-ok 179 [59.126]
<- [59.126]
->N180 G1 X-10.294 Y4.493 E15.47139*78 [59.128]
<-ok 180 [59.217]
<- [59.221]
->N181 G1 X-10.63 Y4.258 E15.49212*112 [59.223]
<-ok 181 [59.308]
<- [59.308]
->N182 G1 X-10.906 Y3.982 E15.51185*70 [59.309]
<-ok 182 [59.397]
<- [59.410]
->N183 G1 X-11.141 Y3.646 E15.53257*68 [59.411]
<-ok 183 [59.488]
<- [59.717]
->N184 G1 X-11.308 Y3.288 E15.55253*72 [59.718]
<-ok 184 [59.724]
<- [59.724]
->N185 G1 X-11.413 Y2.898 E15.57293*64 [59.725]
<-ok 185 [59.734]
<- [59.734]
->N186 G1 X-11.448 Y2.5 E15.59309*77 [59.735]
<-ok 186 [59.761]
<- [59.761]
->N187 G1 X-11.448 Y-2.499 E15.84537*107 [59.763]
<-ok 187 [59.851]
<- [59.853]
->N188 G1 X-11.413 Y-2.897 E15.86558*99 [59.854]
<-ok 188 [59.888]
<- [59.904]
->N189 G1 X-11.308 Y-3.287 E15.886*101 [59.906]
<-ok 189 [60.089]
<- [60.092]
->N190 G1 X-11.141 Y-3.645 E15.90596*109 [60.094]
<-ok 190 [60.127]
<- [60.127]
->N191 M105*46 [60.128]
<-ok 191 [60.163]
<- [60.197]
->N192 G1 X-10.906 Y-3.981 E15.92666*108 [60.198]
<-ok 192 [60.237]
<- [60.383]
<-T:222.86 B:80.50 B@:255 @:255 [60.383]
<- [60.383]
->N193 G1 X-10.63 Y-4.257 E15.94636*83 [60.385]
<-ok 193 [60.392]
<- [60.392]
->N194 G1 X-10.294 Y-4.492 E15.96704*99 [60.393]
<-ok 194 [60.400]
<- [60.400]
->N195 G1 X-9.936 Y-4.659 E15.98695*91 [60.402]
<-ok 195 [60.409]
<- [60.409]
->N196 G1 X-9.547 Y-4.764 E16.00725*85 [60.410]
<-ok 196 [60.417]
<- [60.417]
->N197 G1 X-8.724 Y-4.832 E16.04888*82 [60.418]
<-ok 197 [60.425]
<- [60.425]
->N198 G1 X-8.312 Y-4.93 E16.07021*103 [60.426]
<-ok 198 [60.433]
<- [60.433]
->N199 G1 X-7.92 Y-5.093 E16.09161*104 [60.434]
<-ok 199 [60.442]
<- [60.442]
->N200 G1 X-7.559 Y-5.316 E16.11301*90 [60.443]
<-ok 200 [60.470]
<- [60.573]
->N201 G1 X-7.236 Y-5.591 E16.13441*93 [60.574]
<-ok 201 [60.581]
<- [60.581]
->N202 G1 X-6.961 Y-5.913 E16.15578*93 [60.583]
<-ok 202 [60.589]
<- [60.589]
->N203 G1 X-6.74 Y-6.274 E16.17716*96 [60.590]
<-ok 203 [60.671]
<- [60.675]
->N204 G1 X-6.578 Y-6.669 E16.19873*84 [60.676]
<-ok 204 [60.757]
<- [60.767]
->N205 G1 X-6.481 Y-7.079 E16.22003*83 [60.769]
<-ok 205 [60.839]
<- [60.972]
->N206 G1 X-6.448 Y-7.491 E16.24094*95 [60.973]
<-ok 206 [60.978]
<- [60.978]
->N207 G1 X-6.442 Y-16.449 E16.69306*96 [60.980]
<-ok 207 [60.990]
<- [60.990]
->N208 G1 X6.44 Y-16.449 E17.3431*78 [60.992]
<-ok 208 [60.998]
<- [60.998]
->N209 G1 X6.45 Y-7.635 E17.78785*71 [60.999]
<-ok 209 [61.298]
<- [61.364]
->N210 G1 X6.483 Y-7.076 E17.81606*124 [61.366]
<-ok 210 [61.859]
<- [61.859]
->N211 G1 X6.583 Y-6.658 E17.8377*69 [61.861]
<-ok 211 [62.621]
<- [62.723]
->N212 G1 X6.745 Y-6.269 E17.85892*125 [62.725]
<-ok 212 [62.731]
<- [62.731]
->N213 M105*39 [62.732]
<-ok 213 [62.809]
<- [62.906]
->N214 G1 X6.969 Y-5.906 E17.8804*64 [62.907]
<-T:222.00 B:80.41 B@:255 @:255 [62.911]
<- [62.911]
<-ok 214 [62.911]
<- [62.911]
->N215 G1 X7.244 Y-5.587 E17.90162*121 [62.912]
<-ok 215 [62.920]
<- [62.920]
->N216 G1 X7.567 Y-5.312 E17.92299*115 [62.921]
<-ok 216 [63.042]
<- [63.113]
->N217 G1 X7.928 Y-5.09 E17.94436*73 [63.115]
<-ok 217 [63.121]
<- [63.121]
->N218 G1 X8.322 Y-4.929 E17.96582*127 [63.122]
<-ok 218 [63.203]
<- [63.297]
->N219 G1 X8.734 Y-4.832 E17.98716*119 [63.298]
<-ok 219 [63.306]
<- [63.306]
->N220 G1 X9.549 Y-4.764 E18.02843*123 [63.307]
<-ok 220 [63.399]
<- [63.480]
->N221 G0 F18000 X9.5 Y-4.467*86 [63.482]
<-ok 221 [63.489]
<- [63.489]
->N222 G0 X9.526 Y-4.393*2 [63.490]
<-ok 222 [63.584]
<- [63.664]
->N223 G0 X9.484 Y-4.368*14 [63.665]
<-ok 223 [63.673]
<- [63.673]
->N224 G0 X8.671 Y-4.437*13 [63.675]
<-ok 224 [63.764]
<- [63.846]
->N225 G0 X8.201 Y-4.548*6 [63.847]
<-ok 225 [63.858]
<- [63.858]
->N226 G0 X7.747 Y-4.733*3 [63.859]
<-ok 226 [63.948]
<- [63.948]
->N227 G0 X7.332 Y-4.988*10 [63.950]
<-ok 227 [64.038]
<- [64.045]
->N228 G0 X6.961 Y-5.303*0 [64.047]
<-ok 228 [64.141]
<- [64.148]
->N229 G0 X6.646 Y-5.67*58 [64.149]
<-ok 229 [64.177]
<- [64.177]
->N230 M105*38 [64.178]
<-ok 230 [64.214]
<- [64.216]
->N231 G0 X6.389 Y-6.086*9 [64.217]
<-ok 231 [64.251]
<- [64.267]
<-T:222.29 B:80.32 B@:255 @:255 [64.267]
<- [64.267]
->N232 G0 X6.202 Y-6.535*5 [64.269]
<-ok 232 [64.276]
<- [64.276]
->N233 G0 X6.088 Y-7.017*0 [64.277]
<-ok 233 [64.288]
<- [64.288]
->N234 G0 X6.05 Y-7.623*51 [64.289]
<-ok 234 [64.320]
<- [64.320]
->N235 G0 X6.173 Y-13.429*63 [64.321]
<-ok 235 [64.357]
<- [64.369]
->N236 G0 X5.619 Y-14.92*7 [64.370]
<-ok 236 [64.390]
<- [64.390]
->N237 G0 X5.691 Y-15.69*3 [64.392]
<-ok 237 [64.427]
<- [64.438]
->N238 G0 X5.317 Y-15.735*57 [64.439]
<-ok 238 [64.461]
<- [64.461]
->N239 G0 X5.35 Y-15.649*1 [64.462]
<-ok 239 [64.529]
<- [64.539]
->N240 G0 X5.35 Y-15.649*15 [64.540]
<-ok 240 [64.546]
<- [64.546]
->N241 G0 X5.35 Y-15.349*11 [64.547]
<-ok 241 [64.554]
<- [64.554]
->N242 G1 F720 X-5.348 Y-15.349 E18.56831*53 [64.556]
<-ok 242 [64.563]
<- [64.563]
->N243 G1 X-5.348 Y15.349 E20.11744*79 [64.564]
<-ok 243 [64.673]
<- [64.681]
->N244 G1 X5.35 Y15.349 E20.65727*90 [64.682]
<-ok 244 [64.716]
<- [64.716]
->N245 G1 X5.35 Y-15.349 E22.20645*112 [64.717]
->N1 M110 S1*96 [65.888]
->N2 M104 S0*103 [65.889]
<-ok 245 [66.631]
<- [66.747]
->N3 M104 T0 S0*34 [66.748]
<-ok [67.578]
<- [67.718]
<-ok 2 [67.718]
<- [67.718]
->N4 M105*35 [67.720]
<-ok 3 [70.085]
<- [70.212]
->N5 M140 S0*96 [70.213]
<-TargetExtr0:0 [71.595]
<- [71.648]
<-Printed filament:0.62m Printing time:0 days 1 hours 10 min [71.648]
<- [71.648]
<-ok 4 [71.648]
<- [71.649]
<-TargetExtr0:0 [71.649]
<- [71.649]
<-ok 5 [71.649]
<- [71.649]
<-T:222.86 B:80.06 B@:255 @:255 [71.649]
<- [71.649]
<-TargetBed:0 [71.649]
<- [71.649]
->N6 G28*21 [71.650]
<-ok 6 [71.653]
<- [71.653]
->N7 M114*32 [71.654]
<-ok 7 [71.690]
<- [71.690]
<-X:0.00 Y:0.00 Z:373.56 E:22.20 [75.824]
<- [75.916]
->N8 M4*47 [75.917]
->Communication State: Connected
<-ok 8
->M84
<-ok 8
->M105
<-ok 8
<-T:221.43 B:79.86 B@:0 @:0
<-wait
<-wait
->M105
<-ok 8
<-T:220.57 B:79.80 B@:0 @:0
<-wait
<-wait
->M105
<-ok 8
<-T:219.77 B:79.69 B@:0 @:0
<-wait
->M105
<-ok 8
<-T:219.55 B:79.66 B@:0 @:0
<-wait
<-wait
->M105
<-ok 8
<-T:218.64 B:79.52 B@:0 @:0
<-wait
->M104 T0 S228
<-ok 8
<-TargetExtr0:228
->M105
<-ok 8
<-T:217.05 B:79.39 B@:0 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:215.91 B:79.25 B@:0 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:214.09 B:79.15 B@:0 @:255
<-wait
->M105
<-wait
<-ok 8
<-T:213.18 B:78.98 B@:0 @:255
<-wait
->M140 S80
<-ok 8
<-TargetBed:80
<-wait
->M105
<-ok 8
<-T:213.18 B:78.87 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:212.27 B:78.70 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:212.05 B:78.57 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:211.36 B:78.40 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:211.36 B:78.19 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:211.36 B:78.02 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:212.27 B:77.92 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:212.27 B:77.78 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:212.27 B:77.75 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:212.27 B:77.61 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:212.27 B:77.51 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:212.27 B:77.47 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:212.95 B:77.37 B@:255 @:255
<-wait
->M105
<-wait
<-ok 8
<-T:213.18 B:77.34 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-wait
<-wait
->M105
<-ok 8
<-T:213.86 B:77.27 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:214.09 B:77.24 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:214.09 B:77.20 B@:255 @:255
<-wait
->M105
<-wait
<-ok 8
<-T:214.77 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:215.00 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:215.45 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:215.91 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:216.14 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:216.82 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:217.73 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:217.95 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-wait
<-wait
->M105
<-ok 8
<-T:218.64 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-wait
<-wait
->M105
<-ok 8
<-T:219.09 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:219.55 B:77.20 B@:255 @:255
<-wait
<-wait
->M105
<-ok 8
<-T:219.77 B:77.20 B@:255 @:255
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
<-wait
I did check that the mater control slicer is being used and nothing jumped out of the slicer setting jumped out at me
at my level of knowledge (low) I don't think I should be attempting to install let alone use other software... with MC i have the instructions in the user guide to help me.
Posted: Tue Dec 29, 2015 3:31 pm
by Earthbound
I suspect that the version of Matter Control you are using is not the same as the one in the Max instruction manual. If you can get an older release of MC, the one used in the manual, use it.
The positioning problem you are wrestling with is a Matter Control problem, not a printer issue.
Posted: Tue Dec 29, 2015 4:12 pm
by Windshadow
Earthbound wrote:I suspect that the version of Matter Control you are using is not the same as the one in the Max instruction manual. If you can get an older release of MC, the one used in the manual, use it.
i got a fresh copy via the link in the manual it points to the DL area of SeeMeCNC and its the same version build 1.4.0.5454
could it be a mangled config file for the software? if so how do I clear it?
the menus don't work like a proper OS X application should
the apple menu and the application name menu in the top menu bar of the screen are dead so there is no preferences tab to check
Posted: Tue Dec 29, 2015 4:24 pm
by Windshadow
I tried selecting a different slicer from the default MC one but it just says slicer error even with the one layer test prints and to reset the config so I went back to the MC one I have disconnected and reconnected all to no avail
Posted: Wed Dec 30, 2015 12:10 am
by thedoble
Can you use Grab to post a screenshot of your Settings > Printer tab?
Have you tried printing off the SD card?
Posted: Wed Dec 30, 2015 10:24 am
by RocketMagnet
I'd definitely disconnect your printer from the computer and set your Z height then run a simple file from the SDCard.
If not then try Repetier Host coupled with Slicer or Cura (setup is covered in the older manuals) in the meantime to get up and printing.
I've personally not had much luck with MC and experienced the exact same issue (MC gets the Z height wrong even when its set correctly in the EEPROM and works perfectly in Repetier Host). At as guess I would say its related to the bed levelling as when I looked at this issue the EEROM value was definitely correct but it still printed above the bed.
So I'd personally rule out MC, if it works in Repetier then you will know for certain that its MC setup.
Posted: Wed Dec 30, 2015 11:43 am
by Windshadow
Thanks Guys I am about to start on this with this email from JJ in support I have not in fact tried to use the SD card I will keep it in mind incase this is a bug in the current version of MC
L. Randolph,
I will be happy to help you get to the bottom of things here. From reading all the information from your posts on the forum, it seems like the best approach will be to being with a fresh install of the firmware after a clearing of the EEPROM and then we will go from there addressing one issue at a time (if there are still any) Before clearing the EEPROM, lets go ahead and access the EEPROM and write down the horizontal radius and Z max length so we can enter that back into the EEPROM after the new install. This will help so we do not have to re-calibrate the machine.
Clear the EEPROM
Here is a fresh copy of the firmware to download:
https://github.com/seemecnc/Repetier-09 ... b16b85.zip
Open the Firmware and lets make some modifications In the configuration.h tab:
- Line 701: Change the motor Current to: 145,145,145,145,0
Upload the firmware
Next lets make some changes to the EEPROM
- Change the Horizontal Radius and Z max length to the value that you previously recorded
- Change the Diagonal Rod Length to 290.8
- Change the BED PID drive max to 255
- Change the BED PID max value [0-255] to 255
- Change the EXTR.1 PID drive max to 255
Save these values to the EEPROM
Next, preheat the hot end and bed, and perform a Z Height calibration via the LCD controller to ensure that this setting is accurate after the changes and we don't crash the bed.
Finally, run a print and see if things have improved.
Let me know how this goes. We will be on the live chat today if we can further assist you.
JJ
SeeMeCNC
Re: Can no longer print at all (Progress)
Posted: Wed Dec 30, 2015 1:46 pm
by Windshadow
Well the Powersupply was set at 220 as shipped which might be at the core of my problems so I have reset it to 115V and I
am doing the initial calibration from the start as if I had not run it at all
I do wonder why JJ says to use 145 rather than the 155 for the motor current in the build manual but I have made the changes he specified and after lunch I will start afresh.
thanks for all the help guys
Posted: Wed Dec 30, 2015 3:02 pm
Motor current depends a lot on the motors, they've changed supplier several times over the years.
The higher it is the hotter they will run, but to a point they will put out more torque, generally lower results in quieter operation also.
Re: Can no longer print at all SOLVED PS was set to 220 not
Posted: Wed Dec 30, 2015 5:38 pm
by Windshadow
All seems to be well knock wood
This is my second file to try to print the layer fan
I took there tries with the low voltage to the heaters to get the PEEK fan shroud printed useably
but this is just the first thing off the plate after setting the voltage properly on the PS and recalibrating.
[img]
https://dl.dropboxusercontent.com/u/819 ... 0fan1.jpeg[/img]
I am very pleased
with this progress it is far better than i imagined my first prints would look like after talking to friends who related tales of failure after failure with their Cartesian printers
it actually feels safe to fit the smoked plastic covers now
Re: Can no longer print at all SOLVED PS was at 220v not 115
Posted: Thu Dec 31, 2015 3:54 am
by thedoble
Congrats, surprised it powered up at all with the PS voltage set wrong
