Greetings, all. I've been lurking here for over a year (bought my Rostock V2 in 11/2014), and have enjoyed and appreciated all the advice and wisdom I've been able to pick up.
I used my printer extensively for the first few months, then it got packed away last spring for an upcoming house move, and I'm just now getting it set up again. I upgraded to the current ball joint carriages and arms. Everything is functioning, but I'm trying to get the end-stop calibration (i.e. flat Z) dialed in better. I purchased the usual Pittsburgh/Cen-tech (Harbor Freight) digital depth indicator, and drew up a mount for it, based on the current ball joint effector plate STL. I run a modified "all towers cal" from the current build instructions, adjusting Z heights and speed to accommodate the gauge.
All in all, with learning the best Z height range for the gauge, a few turns on the wrong tower, etc., I recorded 42 iterations. The gauge reads to 0.01mm, claims accuracy to 0.001" (0.0254mm), and so I consider +/- 0.01mm to be as good as I'm going to get. The gauge does seem to be very repeatable, which for this test is much more important than accuracy. Each time I got close to equal readings (i.e. XYZ all within 0.01mm of each other), I did 2 more iterations without making adjustments to check for consistency - they were always very stable. Then I tweaked EEPROM horizontal radius, and started over again if necessary.
After dialing everything in better than I thought I would be able to, I decided to rotate the effector plate to another set of arms to verify. Bad news: stable, repeatable values, but not level (X now 0.3mm high, Y 0.4 low, Z 0.2 low, but center still spot on); rotating to the other arms gave me different but still very uneven values. I thought "OK, the plate/ball clips/gauge aren't perfectly level, I can live with that." I then moved it back to the original mounting arms and it came out uneven again, though not as bad as with the other mounting locations. Now I'm wondering how can I trust any of these measurements? Due to having to swap ball clips from the dial plate back to the hot-end plate, I haven't yet run a thin print to visually check flatness.
How do you guys run your dial/digital indicators? Do you verify by mounting in different arms?
Thanks,
Mike
Setting end-stop screws for level Z
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- Software
- ↳ Orca Slicer
- ↳ SuperSlicer
- ↳ Cura
- ↳ Simplify3D
- ↳ Slic3r
- ↳ KISSlicer
- ↳ Repetier Host
- ↳ OctoPrint
- ↳ Other
- ↳ Sculptris
- ↳ OpenSCAD
- ↳ FreeCAD
- ↳ Blender
- ↳ SolidWorks
- ↳ AutoDesk 123D
- ↳ EMC2/LinuxCNC
- ↳ Skeinforge
- ↳ Mach3 Software
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
