Rostock Max v2 Perfect PLA/Horrible ABS Prints - Help!
Posted: Sat Feb 13, 2016 12:05 pm
Hi All,
I have a Rostock max v2 with Tricklaser arms, E3D v6, stock extruder, trucks, and extruder platform. I use Buildtak sheets on my build plate because I love the finish it gives PLA prints as well as being much easier to remove prints. For calibration I will either use a .051mm feeler gauge, paper, or if I really want to do it right I will break out the tricklaser tool mount and slip my dial indicator into it. (Considering whether I should switch to magnetic arms to make changing tools easier)
Ever since I got my printer I have struggled to print ABS. It seems no matter how much I mess with the calibration, e-steps, temperatures, etc. ABS prints always turn into a gloppy mess on the build platform. At first I thought this was due to the temps or over-extrusion because it seems like there is more material being spit out than when I print PLA. If I print a single layer out of PLA the result is a perfectly smooth shiny surface, but with ABS it is rough, uneven, with large globs of material everywhere.
For settings I typically start with the Seemecnc default profiles and print at 228/80 for ABS but I have tried as low as 224 and as high as 240 and everywhere in between. In addition, I have messed with different speeds and layer heights with no effect. Having just done a dial indicator calibration I know it is spot on, so what am I doing wrong here? I thought it was the buildtak, but I see now that they advertise support for multiple materials, and I have had the same problems using masking tape, pei, and glue sticks.
I do not have a layer fan on my machine currently, will adding one help with this issue by cooling the abs which in turn will help to "freeze it in place" once its extruded?
Thanks in advance for any help!
