Rostock MAX with RAMPS 1.4 Motor Skipping
Posted: Sat Dec 22, 2012 1:26 pm
I have assembled a Rostock MAX using the RAMPS 1.4 board. However, I'm having an issue with the motors skipping. I've tried adjusting the pots on the stepper drivers. I've taken the arms completely apart and filed all the joints to ensure everything moves easily. When I turn the stepper shaft by hand, it really isn't that difficult. The motors move just fine when loading the firmware for the original Rostock, so my concern is maybe there is a setting I'm missing in the Rostock MAX firmware that is causing my issue. I've changed the motherboard setting in the Configuration.h for the Rostock MAX firmware to 34 (RAMPS 1.3).
Can someone that knows a bit more than I about this topic provide me some direction? Perhaps the micro-stepping is different, on the original Rostock wiki page it implies that 16x micro-stepping is being used, and on the Rostock MAX wiki page it implies that 8x micro-stepping is being used. Could that have something to do with it? Also, I'm using NEMA 17 motors.
Dylan
Dylan
