calibration/first time delta build
Posted: Thu Mar 03, 2016 4:33 pm
Hello all, I'm Feron, and I'm a newb :/
So I've gotten my Rostock V2 built and am on to the calibration.
So far everything has checked out electronics and movement wise.
My only deviation in the build has been installing the 300mm cf arms from tricklaser instead of the stock arms.
Well, using the provided tower calibration script I'm seeing I can get the x and y about right, very little margin of change in the paths, however the z is practically flying away.. about a quarter inch above the glass plate with the end stop screw as far out as it can possibly be.
I've checked arm length, screws/riser everywhere, squareness, lengths from plate to end stop matching up on all axis...
Any helpful pointers, tips, tricks or otherwise useful information about a problem of this sort?
Thanks in advance.
Thanks in advance.
