Rostock MAX v1 DUET configuration...
Posted: Fri Mar 04, 2016 3:02 pm
Attached are my config.g and bed.g files as used in Blue MAX.
config.txt
(5.01 KiB) Downloaded 441 times
bed.txt
(1.83 KiB) Downloaded 375 times
You'll need to rename them from ".txt" to ".g" to use.
Blue MAX is a v1 that's been upgraded to use the new injection molded carriages and the ball & socket arms.
If you've got a v1 with the original, stock arms you'll need to make a couple of changes.
Search for this line: M665 R144 L290.8 B140 H360.0. Change "R144" to "R135" and "L290.8" to "L269". "H360.0" will be around 345. You'll need to experiment on that one a bit.
The bed.g file is used for auto-calibration. I've changed the file to that it does NOT perform a G28 after the calibration is done. I did this because of concerns that an ill-behaved end stop switch could interfere with the calibration that was just performed.
Re: Rostock MAX v1 DUET configuration...
Posted: Fri Mar 04, 2016 7:15 pm
by 3D-Print
Awesome. Thank you!!!
Posted: Sat Mar 05, 2016 12:24 am
by DerStig
Thank You!
No to hopefully understand how to use it!
Posted: Sat Mar 05, 2016 7:12 am
by DavidF
Thanks Gene!!
Posted: Sat Mar 05, 2016 11:24 pm
You're welcome. Hopefully it'll be useful to someone. :)
I finished upgrading Red Sonja to the Duet today, including using one of those little TP-Link Wifi to Ethernet bridges. It's pretty slick. You do need to make sure that the IP addresses you assign the Duet & the TP-Link are on the same subnet as the rest of your network. :)
Red Sonja actually got a mounted Duet vs the hatchet job that Blue MAX got. :)
Orange Menace will be the next one in line, but I need to save up my pennies to get a 3rd Duet. :)
Posted: Sun Mar 06, 2016 10:00 am
geneb wrote:You're welcome. Hopefully it'll be useful to someone. :)
Saving pennies is the one I know the most about!
Don't let anyone tell you that retirement is great.......Retirement sucks for the average person who doesn't have a million in the bank.
Even a million is not enough if you have major medical problems. So here is the solution, everyone must save 5 million or do not retire. :D
Posted: Sat Mar 26, 2016 9:20 am
by Great_Thark
I started with your files, thank you.
An interesting note, I have no idea why, but I am using the diff IR probe and the 6 factor calculation threw everything a mile out. I changed it to 7 and it's working beautifully.
