Tin foil is indeed aluminum foil. If it were actual tin, it would not be as useful since it would have lower thermal conductivity. The suitable DC SSR is the
100A one (Yes, it is very oversized, but the others are undersized). With the low on resistance it exhibits, there's minimal power loss to it, and it should stay cool.
As for all in one stores, I'm sorry to say that I don't think so. My biggest bit of advice as far as stores. If the quality matters, buy from either the mfg. directly, or an industrial supplier. Don't trust Ali, ebay, or amazon, unless someone else has used that exact part and it worked.
And a last point. Filament matters. Some applications need higher quality filaments even if they are in theory the same plastic. Don't try using 15$ Amazon filament for high detail work. And colorants can matter. As an example, I often use Designshop or Hatchbox ABS filament with a .4 nozzle. It's kinda stringy, and the diameter isn't always great, but it works and is cheap. But I'm getting ready to work up some high detail prints. For those, I'll be using MG94 ABS and PMMA (Acrylic filament). Now, most high detail stuff doesn't need that, but I'll be seeing if I can get a .15mm nozzle working on a V2, and it very much does. I also find that avoiding colorants usually produces a better filament, so if you use bargain basement stuff, go for the natural colors. It lets you see fillers and other issues more easily. Red and black are usually the colors with the most filament issues, as well.
