Boro Glass Build Plate vs FabLam Flex
Posted: Thu Oct 01, 2020 5:56 pm
I had a problem using my stock borosilicate build surface with a PETG part. After printing and letting everything cool completely, the part came off with three chunks of glass attached to it. The plate didn't crack, but there are now three divots of about .4" across and maybe 1/16 " deep in the print bed. This was an unexpected result to say the least. I have purchased a replacement build plate, but now I'm afraid to use it since the last one failed after only a few months. I'd like to use the FabLam Flex™ Spring Steel Bed Plate, but the website says "magnetic plate needed." I can't find any info on this alleged magnetic build plate. Here are my questions:
1. Has anyone else had similar problems with chunks coming out of their borosilicate build surface?
2. Where does one obtain the magnetic build plate that goes with the FabLam Flex™ Spring Steel Bed Plate? Alternatively, where can more information be found?
3. Has anyone used the FabLam Flex™ Spring Steel Bed Plate and do you think it was a worthwhile upgrade?
Thanks in advance for your advice.
