Here's some Slic3r profiles to get you going. Keep in mind that I'm no expert...
I usually keep my Slic3r profiles with my STL models, naming them similar to what I'm printing. And even making a nozzle note or filament note.
Good general straight wall:
Fair Solid:
Creature Feature (like yoda):
~PartDaddy~
Slic3r 0.7.2b Profiles to get you started
- Site Admin
Re: Slic3r 0.7.2b Profiles to get you started
I was reading your .ini files and it says bed is 200x200. Are you using the full area available for the bed? and is the size metric?
Thanks,
jim
Thanks,
jim
Jim, john here. Steve must have left that as the default. I usually have it set to 185*185, and yes that is in mm
