I've tried a bunch of things and started over with fresh configs so that I don't get to far off track.
First thing was changing the FEATURE_CONTROLLER to 11 in configuration.h. At different times, I have also tried to for it to UI_LANGUAGE 0, due to me changing the uimenu.h to the vanilla repetier. This has not yielded any fruit either so I am still using the SeeMeCNC .91 firmware.
I've also changed the ui.h file to reflect the FEATURE_CONTROLLER 13 (Rambo) pins.
To account for the SDCARDDETECT Pin
#if FEATURE_CONTROLLER==2 || FEATURE_CONTROLLER==10 || FEATURE_CONTROLLER==11 // reprapdiscount smartcontroller has a sd card buildin
#undef SDCARDDETECT
#define SDCARDDETECT 81
#undef SDCARDDETECTINVERTED
#define SDCARDDETECTINVERTED false
#undef SDSUPPORT
#define SDSUPPORT true
#endif
I'm sure there are other things that I've been trying but does anyone have any tip?#if FEATURE_CONTROLLER==2 || FEATURE_CONTROLLER==10 || FEATURE_CONTROLLER==11 // reprapdiscount smartcontroller (2) gadgets3d (10)
#define UI_HAS_KEYS 1
#define UI_HAS_BACK_KEY 0
#if FEATURE_CONTROLLER==11
#define UI_DISPLAY_TYPE 5
#define U8GLIB_ST7920
#define UI_LCD_WIDTH 128
#define UI_LCD_HEIGHT 64
//select font size
#define UI_FONT_6X10 //default font
#ifdef UI_FONT_6X10
#define UI_FONT_WIDTH 6
#define UI_FONT_HEIGHT 10
#define UI_FONT_SMALL_HEIGHT 7
#define UI_FONT_DEFAULT repetier_6x10
#define UI_FONT_SMALL repetier_5x7
#define UI_FONT_SMALL_WIDTH 5 //smaller font for status display
#define UI_ANIMATION false // Animations are too slow
#endif
//calculate rows and cols available with current font
#define UI_COLS (UI_LCD_WIDTH/UI_FONT_WIDTH)
#define UI_ROWS (UI_LCD_HEIGHT/UI_FONT_HEIGHT)
#define UI_DISPLAY_CHARSET 3
#else
#define UI_DISPLAY_TYPE 1
#define UI_DISPLAY_CHARSET 1
#define UI_COLS 20
#define UI_ROWS 4
#endif
#define BEEPER_TYPE 1
#if FEATURE_CONTROLLER==10 // Gadgets3d shield
#define BEEPER_PIN 33
#define UI_DISPLAY_RS_PIN 16
#define UI_DISPLAY_RW_PIN -1
#define UI_DISPLAY_ENABLE_PIN 17
#define UI_DISPLAY_D0_PIN 23
#define UI_DISPLAY_D1_PIN 25
#define UI_DISPLAY_D2_PIN 27
#define UI_DISPLAY_D3_PIN 29
#define UI_DISPLAY_D4_PIN 23
#define UI_DISPLAY_D5_PIN 25
#define UI_DISPLAY_D6_PIN 27
#define UI_DISPLAY_D7_PIN 29
#define UI_ENCODER_A 35
#define UI_ENCODER_B 37
#define UI_ENCODER_CLICK 31
#define UI_RESET_PIN 41
#else // Smartcontroller
#if MOTHERBOARD==80 // Rumba has different pins as RAMPS!
#define BEEPER_PIN 44
#define UI_DISPLAY_RS_PIN 19
#define UI_DISPLAY_ENABLE_PIN 42
#define UI_DISPLAY_D0_PIN 18
#define UI_DISPLAY_D1_PIN 38
#define UI_DISPLAY_D2_PIN 41
#define UI_DISPLAY_D3_PIN 40
#define UI_DISPLAY_D4_PIN 18
#define UI_DISPLAY_D5_PIN 38
#define UI_DISPLAY_D6_PIN 41
#define UI_DISPLAY_D7_PIN 40
#define UI_ENCODER_A 12
#define UI_ENCODER_B 11
#define UI_ENCODER_CLICK 43
#define UI_RESET_PIN 46
#else
#define BEEPER_PIN 79
#define UI_DISPLAY_RS_PIN 70
#define UI_DISPLAY_ENABLE_PIN 71
#define UI_DISPLAY_D0_PIN -1
#define UI_DISPLAY_D1_PIN -1
#define UI_DISPLAY_D2_PIN -1
#define UI_DISPLAY_D3_PIN -1
#define UI_DISPLAY_D4_PIN 72
#define UI_DISPLAY_D5_PIN 73
#define UI_DISPLAY_D6_PIN 74
#define UI_DISPLAY_D7_PIN 75
#define UI_ENCODER_A 77
#define UI_ENCODER_B 76
#define UI_ENCODER_CLICK 78
#define UI_RESET_PIN 80
#endif
#endif
#define UI_DELAYPERCHAR 320
#define UI_INVERT_MENU_DIRECTION true
#ifdef UI_MAIN
void ui_init_keys() {
UI_KEYS_INIT_CLICKENCODER_LOW(UI_ENCODER_A,UI_ENCODER_B); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
UI_KEYS_INIT_BUTTON_LOW(UI_ENCODER_CLICK); // push button, connects gnd to pin
UI_KEYS_INIT_BUTTON_LOW(UI_RESET_PIN); // Kill pin
void ui_check_keys(int &action) {
UI_KEYS_CLICKENCODER_LOW_REV(UI_ENCODER_A,UI_ENCODER_B); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
UI_KEYS_BUTTON_LOW(UI_ENCODER_CLICK,UI_ACTION_OK); // push button, connects gnd to pin
UI_KEYS_BUTTON_LOW(UI_RESET_PIN,UI_ACTION_RESET);
inline void ui_check_slow_encoder() {}
void ui_check_slow_keys(int &action) {}
#endif
Thanks
