can someone delete this?
EddyGara
Post by EddyGara »
can some one delete this?
EddyGara
Re: 6ft tall Rostock Max build!
Post by EddyGara »
s
EddyGara
Post by EddyGara »
moved to new thread
bob64
Post by bob64 »
you're supposed to print a belt spacer clamp thingy to secure the belts.
Rostock Max V2 with mods:
E3d v6 with 713maker mount & e3d titan extruder
Tricklaser CF arms, heat spreader, tricktrucks, fly-n-strude, metal carriage & effector
Duet v.8.5.0
24v MeanWell 750w PS & Cydom D1D40 SSR in parallel with stock 12v PS
EddyGara
Post by EddyGara »
Well I did that, but I think the spacers were ment to be used with all but the max metal brackets. So they didn't fit at all when I tried to use them. I'm not sure what else I can do. I haven't install the carbon arms yet because I just don't think the whole configuration of the belts and mounts is sturdy enough. I'll post pics in the morning of the belt clamps not working.
ccavanaugh
Post by ccavanaugh »
Belt spacer clamps are not used with the TrickLaser brackets.
SeeMeCNC belting is thicker than some others and works better. If needed, a few layers of kapton tape or some other type of shim material placed in the slot will increase the clamp pressure.
bob64
Re: can someone delete this?
Post by bob64 »
Derp. It's ironic that I just hit the same issue with my new build lol. He actually supplies some.... aluminum tape looking shim material with it.
Duet v.8.5.0
Return to “Mods and Upgrades”
