can someone delete this?
Posted: Sat Apr 02, 2016 5:06 pm
by EddyGara
can some one delete this?
Re: 6ft tall Rostock Max build!
Posted: Sat Apr 02, 2016 5:18 pm
by EddyGara
s
Posted: Sat Apr 02, 2016 5:35 pm
by EddyGara
moved to new thread
Posted: Sat Apr 02, 2016 10:34 pm
by bob64
you're supposed to print a belt spacer clamp thingy to secure the belts.
Posted: Sun Apr 03, 2016 1:09 am
by EddyGara
Well I did that, but I think the spacers were ment to be used with all but the max metal brackets. So they didn't fit at all when I tried to use them. I'm not sure what else I can do. I haven't install the carbon arms yet because I just don't think the whole configuration of the belts and mounts is sturdy enough. I'll post pics in the morning of the belt clamps not working.
Posted: Sun Apr 03, 2016 6:42 am
by ccavanaugh
Belt spacer clamps are not used with the TrickLaser brackets.
SeeMeCNC belting is thicker than some others and works better. If needed, a few layers of kapton tape or some other type of shim material placed in the slot will increase the clamp pressure.
Re: can someone delete this?
Posted: Sat Apr 16, 2016 9:44 pm
by bob64
Derp. It's ironic that I just hit the same issue with my new build lol. He actually supplies some.... aluminum tape looking shim material with it.
