First off here's some pictures of what the problems are:
The pillars do not have solid exteriors:
[img]http://i.imgur.com/WQfH8Nv.jpg[/img]
The top surface has gaps:
[img]http://i.imgur.com/RrQhz0U.jpg[/img]
The back sides are not too bad, but there are a few small gaps:
[img]http://i.imgur.com/S0t5ieb.jpg[/img]
[img]http://i.imgur.com/izrdo28.jpg[/img]
Below are my KISS Slicer settings. I can post the GCode too, if that's ok with you Mike.
_material
[Hatchbox Blue PLA]
g_code_matl=3B204D617962652073657420736F6D65206D6174657269616C2D737065636966696320472D636F64653F
fan_Z_mm=6
fan_loops_percent=65
fan_inside_percent=65
fan_cool_percent=80
temperature_C=200
keep_warm_C=165
first_layer_C=200
bed_C=72
sec_per_C_per_C=0.00681818
flow_min_mm3_per_s=0.5
flow_max_mm3_per_s=10
destring_suck=2
destring_prime=1.5
destring_min_mm=1.5
destring_trigger_mm=5
destring_speed_mm_per_s=25
destring_suck_speed_mm_per_s=55
Z_lift_mm=0.5
min_layer_time_s=10
wipe_mm=5
cost_per_cm3=0
flowrate_tweak=1
fiber_dia_mm=1.72
color=4294967040
[.2mm Layers]
quality_percentage=60
layer_thickness_mm=0.2
extrusion_width_mm=0.55
num_loops=4
skin_thickness_mm=0.5
infill_extrusion_width=0.55
infill_density_denominator=2
stacked_layers=1
use_destring=1
use_wipe=1
use_corners=1
loops_insideout=0
infill_st_oct_rnd=2
inset_surface_xy_mm=0
seam_jitter_degrees=360
seam_depth_scaler=0
seam_gap_scaler=1
seam_angle_degrees=45
[Rostock MAX]
bed_STL_filename=C:\Users\Tracy\Downloads\KISSlicer_Win32_1.5_Release\RostockBuildPlatform.stl
extension=gcode
cost_per_hour=0
g_code_prefix=4732380A4D31303420533C54454D503E0A4D31393020533C42454454454D503E0A4D31303920533C54454D503E
g_code_warm=3B2053656C6563742065787472756465722C207761726D2C2070757267650A3B2035442D7374796C650A543C4558542B303E0A4D31303420533C54454D503E0A
g_code_same_warm=NULL
g_code_same_cool=NULL
g_code_cool=436F6F6C2047436F64650A3B2047756172616E746565642073616D652065787472756465722C20636F6F6C696E6720646F776E0A3B2035442D7374796C650A4D31303420533C54454D503E0A
g_code_N_layers=3B204D617962652072652D686F6D652058202620593F
g_code_postfix=4731205837302059302046353030300A4732380A4D313430205330203B206B696C6C206265642074656D7065726174757265
every_N_layers=0
post_process=NULL
num_extruders=1
firmware_type=2
add_comments=1
fan_on=M106
fan_off=M107
fan_pwm=1
add_m101_g10=0
z_speed_mm_per_s=15
z_settle_mm=0
bed_size_x_mm=280
bed_size_y_mm=280
bed_size_z_mm=300
ext_radius=0
bed_offset_x_mm=0
bed_offset_y_mm=0
bed_offset_z_mm=0
bed_roughness_mm=0
round_bed=1
travel_speed_mm_per_s=500
rim_speed_mm_per_s=250
first_layer_speed_mm_per_s=10
dmax_per_layer_mm_per_s=50
xy_accel_mm_per_s_per_s=1500
xy_steps_per_mm=150
lo_speed_perim_mm_per_s=10
lo_speed_loops_mm_per_s=20
lo_speed_solid_mm_per_s=10
lo_speed_sparse_mm_per_s=10
hi_speed_perim_mm_per_s=30
hi_speed_loops_mm_per_s=65
hi_speed_solid_mm_per_s=30
hi_speed_sparse_mm_per_s=30
ext_gain_1=1
ext_material_1=7
ext_axis_1=0
