Extruder Melting
Posted: Sat Aug 15, 2015 5:33 pm
by Robaire
I'm running a Rostock Max V2 using Repetier and the extrusion motor is getting so hot it is melting the filament. Is there anything that can be done about this, perhaps machining a heatsink with fan to cool the motor?
Re: Extruder Melting
Posted: Sat Aug 15, 2015 5:50 pm
by Tincho85
What motors do you have? Wantai, Kysan or Automation Technology Inc?
Posted: Sat Aug 15, 2015 5:55 pm
by Tincho85
If the label says Kysan you need to change the the motor current.
Load up your firmware, configuration.h, line 701
change:
#define MOTOR_CURRENT {175,175,175,200,0} // Values 0-255 (RAMBO 135 = ~0.75A, 185 = ~1A)
to:
#define MOTOR_CURRENT {155,155,155,165,0} // Values 0-255 (RAMBO 135 = ~0.75A, 185 = ~1A KYSAN MOTOR CURRENT SETTINGS )
http://forum.seemecnc.com/viewtopic.php ... 24&start=0
Posted: Sat Aug 15, 2015 6:52 pm
by Robaire
I set the initial configuration for the Automation Technology Motors already. But I'll double check and re-upload the firmware.
Posted: Sat Aug 15, 2015 7:42 pm
by Robaire
Despite re-uploading the firmware the motors are still running extremely hot.
Posted: Sun Aug 16, 2015 3:17 am
by teoman
Would you care to quantify extremely hot?
There are some nice fans you can install on the motor. Thingiverse has some good stls.
Posted: Sun Aug 16, 2015 2:17 pm
by Robaire
Unfortunately I don't have a thermocouple so I can't measure exactly but it is much too hot to touch, and is hot enough to melt the PLA filament against the extruder gear. I've ordered some small 40mm x 40mm heat sinks and fans that I plan to mount to all the steppers, hopefully it will help.
Posted: Wed Aug 19, 2015 1:13 pm
by Tincho85
Sorry but I don't want to make a thread for only this question.
I've 1.8deg Wantai motors, rated for 2.5a (42BYGHW811P2) and my settings are:
175 is ok? that is 0.95a...
should I increase it? what are the pro/cons of running them at higher amps?
Btw, they are not even hot to touch when printing.
Posted: Fri Aug 21, 2015 3:03 pm
by Tincho85
No one knows? Please, I want to keep learning
Posted: Sat Aug 22, 2015 1:14 am
by Robaire
Sorry I'm not familiar enough with the motor specs to provide a good answer. There are really no good sides to running at higher amps as far as I know. All that really comes from it is more heat which can only cause problems.
